Each door has a clasp at the top (white plastic part - approx 1.25" long) that "catches" the door. One of mine broke. Cannot find the part reference or number on searsparts.com blow-up parts diagram. Any ideas on how to identify/order? Is it easy to install? Hate to pay a service charge for small simple part. Thanks for help.
SOURCE: Kenmore elite - Water dripping from freezer to refrigerator
Your refrigerator has a defrost drain blockage behind the evaporator in your your freezer compartment. Some models like yours have leak in the turns as the water leaves the freezer. I recommend that you unplug and remove the cover to the evaporator and check the defrost condensate tray below the evaporator. A wet vacuum cleaner and poring a solution with clorox in the drain will help you clean locate the leak and where the blockage may be downline.. I do have the manual on yours and can help you solve this. Some times this is a factory defect and I can help you solve the freezing drain problem. Let me know, Sea Breeze
http://fixitnow.com/wp/2009/05/26/the-permanent-cure-for-repeatedly-freezing-condensate-drains-in-whirlpool-roper-kitchenaid-top-mount-refrigerators/
http://servicepartstec.blogspot.com/
SOURCE: Want to reverse door swing on Kenmore refrigerator model # 795
Actually, I have a Kenmore 795 model with the top door and bottom drawer freezer. I just tried this, based on "guru's" advice. Unfortuately, though the TOP hinge on this model is reversible, the bottom hinge is NOT. I got it all apart before I discovered this problem. Also you might want to note that the 7/16th wrench is too big for my bolts and the 3/8ths is too small. I had to use an adjustable wrench...maybe they are metric.
An allen wrench will get the handles off for you. You will find little ports for it if you look carefully.
SOURCE: Replacing the Ice dispenser motor on Kenmore elite refrigerator?
I had the same problem with our Whirlpool Gold. Which by the way was just out of warranty. The guy who repaired the problem told us that since there were so many replacement dispenser motors at different supply locations that there must be a problem. I think that the root cause is the arm in the ice holder is hard to move, and it burns the dispenser ( #2252130) motor out. Whirlpool should get to the bottom of this and offer free or reduced repairs. Motor # 2252130
SOURCE: INVENSYS CONTROL FOR KENMORE ELITE SIDE BY SIDE
http://midwestapplianceparts.com/refrigerator-freezer-65/kenmore-refrigerator-parts-169/kenmore-water-valves-172/kenmore-refrigerator-water-valve-3268.html
should not only hook u right up but it will the best price ...EVER...
