Question about HP OfficeJet 7310 All-In-One InkJet Printer
Error message: remove and check color cartridge
Have removed and check cart. several times, error still displays
Posted by melsalazar on
  • 1 more comment
  • godfreyv Nov 13, 2007
    My print error maessage continue to show after cleaning heads and adding new tricolor and black print cartridge. What else can I do to correct the problem?
    [email protected]
  • johnnyangel Nov 17, 2007
    I am receiving the same error messsage. I have cleaned contacts and cartridge and then replaced both cartridges and am still getting error message.
  • capecod4 Dec 02, 2007
    Having the same problem plus a two month long conversation with HP in which they keep asking me to repeat the TAP 10 and 11 test. I feel like Iam in a Groundhog day loop. I finally just junked it and bought another printer. NOT HP>
Anonymous
I don't know if anyone else has noticed a similar issue, but when I got the above error messages, I noticed that the wire lever that sits beneath the color cartridge and swings back when the cartridge is inserted had popped out of the plastic notch that holds it and was hanging free.  I haven't been able to get it to stay in position - it pops out again each time I insert the cartridge.  Has anyone figured out a way to get it to stay?  I'm tempted to try and fix it in place with a small amount of adhesive, but I'm afraid if it doesn't work I'll make matters worse.  Has anyone tried this?
Posted on Dec 16, 2007
Thomas Christopher
    Genius:
  • 1,601 Answers
Problem with printer
There can only try and I hope it will do the job for you.
Error 1203 is an issue that occurs either when a cartridge is bad or the printer cartridge Slot is bad...
1 - try cleaning the copper contacts of the both carts and cart slot in the printer and try again..
or
2 - when error shows up, shut the printers power off; wait one minute and turn it back on
press copy
Or if you need to do a factory reset
Reset Factory Defaults on the Dell™ 962 Printer
To reset factory defaults on the printer, perform the following steps:
  1. Press the Mode button several times until the Copy LED is lit.
  2. Press the Menu button until Set Defaults is displayed, then press the Select button.
  3. Press the right arrow button until Restore Factory Defaults is displayed, then press the Select button. The printer will ask for the date, time and language.
Enter the time, date and language, the press the Select button.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
May 03, 2010 | Dell 944 All-In-One InkJet Printer
It says cartridge error consult owners manuel error #1203 but i have dell's ink cartridge in the printer
Hi
Error 1203 Dell
or
press copy
Reset Factory Defaults on the Dell™ Printer
Apr 07, 2010 | Dell 924 All-in-One InkJet Printer
Just replaced color cartridge on my Dell 942 printer - not getting an error 1203 message! HELP!
Hi
Error 1203 Dell 962
or
press copy
Feb 25, 2010 | Dell 924 All-in-One InkJet Printer
Changed ink, cleaned cartridge area, turned printer on and off, still have an error code 1203. what is my next step?
Hi there can only try and I hope it will do the job for you.
or
2 - when error shows up, shut the printers power off; wait one minute and turn it back on press copy.
Or try
  4. Enter the time, date and language, the press the Select button.
Feb 15, 2010 | Dell 962 Photo All-In-One InkJet Printer
Lexmark c510 error message ;83 photodeve cart missing
See User Reference
http://www.lexmark.com/publications/pdfs/c510/eng/userref.pdf
Understanding printer messages
pages 184 and 185
"Message:
83 Photodev Cart Exhausted
What this message means:
The photodeveloper cartridge is completely used.
What you can do:
Replace the photodeveloper cartridge.
See also: Replacing the photodeveloper cartridge [page 73]
Continuing below
Message:
83 Photodev Cart Life Warning
The photodeveloper cartridge is nearing the end of its life.
What you can do:
• Press Go to clear the message and continue printing.
• Replace the photodeveloper cartridge.
Continuing below
Message:
83 Photodev Cart Missing
The photodeveloper cartridge is either missing or incorrectly
installed.
What you can do:
Correctly install the photodeveloper cartridge to clear the message and continue printing.
See also: Replacing the photodeveloper cartridge [page 73] "
Nov 26, 2008 | Lexmark C510 Laser Printer
Lexmark X6170
There will be blue tape when turn the cart upside down please remove the the tape ...and check there no tape :if the printer states the same error remove the cart and check for the error if error is displayed turnoff and remove power adapter for 30 sec and reconnet it back and check for the error If displaye it printer problem..
Feb 19, 2008 | Lexmark X6170 All-In-One InkJet Printer
Ink cartridge (not) installed properly
unplug machine from power outlet. take all carts out. wait 5 min. plug machine to power. wait until machine demands carts. reinsert carts and make sure they are secured. answer display when asked if you have changed.
If you still have the error message use a original brother cart.
Dec 16, 2007 | Brother MFC 210C All-In-One InkJet Printer
Brother MFC-215C
unplug machine from power. remove all carts. close cover. reconnect machine to power. wait until machine demands carts. reinsert cart as demanded by machine and secure them by pressing them into position and fixing the clip above the cart cover. give correct answer as display asks. Set date and time again.
btw: always print until printer stopps printing! Never change cart befor that
because printer logic will be fooled ;-)
Nov 11, 2007 | Office Equipment & Supplies
CHECK BOTH CART. message
Are they original cartridge if not change them for original ones failing this clean the contacts on the cartridges and the carriage.
Thanks J
Oct 13, 2007 | Sharp AJ-5030 InkJet Printer
HP OfficeJet 7310 All-In-One InkJet Printer Logo
387 people viewed this question
Ekse
Thomas F. Schneider
