Question about 2K Games Sid Meier's Civilization V for Windows
How to end turn
When does a turn ends and the next one begins
Ethan Cook
    Habit-Forming:
    New Friend:
  • 13 Answers
To end your turn there is an end turn in the bottom right of the screen, the turn ends when a turn timer (if enabled counts down to zero) or when all human players have pressed end turn.Turns happen one at a time except during wars (on the default settings) and the AI's turns happen simultaneously. For more info on turns look at the ingame turn settings, which explain it a bit.
Posted on Jul 16, 2016
How to make buttonholes to all be in line on a blouse
You need to mark the beginning and end of each buttonhole on your blouse and be sure that you stop the end promptly so you can begin the next buttonhole in the right place.
You might try watching some YouTube tutorials.
sewing machine buttonholes Google Search
Jul 27, 2018 | Sewing Machines
Tip
Filling & draining a waterbed
Although not very scientific they most effective way to ensure your waterbed is filled to the appropriate level and without bubbles is by using a broomstick. Start by filling the mattress about one quarter full with warm water. Next remove the hose from the intake valve and roll a broom handle over the mattress from one end to another to remove air bubbles. Repeat this process three more times until the mattress is full. It is difficult to gauge how much water will be needed exactly since there are many deciding factors. On average a queen size mattress hold approximately 130 gallons of water.
In terms of draining, the easiest way to accomplish this is with a pump. This video tutorial explains how to use an electric pump to drain your waterbed mattress.
http://www.youtube.com/watch?v=Rh7pApujSHI
If you do not have a pump, it may be slightly more difficult. Begin by unplugging your heater. You will then need to attach one end of your garden hose to a faucet outside and the other end to the drain valve of your mattress. Begin by turning the water on for approximately 15 seconds. This will create a siphon. Next you will need to turn off the water and disconnect the hose from the faucet outside. As long as the hose end is lower than the waterbed gravity will do its part in ensuring the water successfully drains out.
on Aug 28, 2012 | Furniture
How should the first stich in each row be knitted. I.e opposite of what the pattern calls for or pulled off Thank you.
The first stitch of the row is usually the chain that you ended in the last row. The chain essentially builds the height of the pattern to the next row so the stitches are even height from beginning to end. After you have made the chain, then begin with the first stitch in the next row pattern.
So, if the pattern says to knit 3 (or purl 3), that 3 stitches allows the height for the next row.
Jul 19, 2017 | Sewing Machines
In what month and year is Mad Men set?
Season 1 opens in March 1960 and finishes Thanksgiving Day, 24th November 1960. Season 2 picks up on Valentine's Day, 14th February 1962 and ends in October 1962 with the peaceful resolution of the Cuban missile crisis. Season 3 starts somewhere during Spring 1963 with Betty Draper (January Jones) being approximately six months pregnant and ends on the evening of 16th December 1963. Season 4 begins around Thanksgiving in November 1964 and ends in October 1965. Season 5 begins on Memorial Day weekend in May 1966 and ends in March 1967. Season 6 begins at Christmastime in December 1967 and ends on Thanksgiving Day, 28th November 1968. Season 7 begins in January 1969, around the inauguration of President Richard Nixon and ends mid-season on the morning of 22nd July 1969, two days after the successful moon landing of Apollo 11.
Sep 04, 2016 | Mad Men (2007)
How do I turn the WiFi on
Open your Internet browser and navigate to the Samsung PC Studio download page
(see Resources for link).
Click the link next to the operating system you currently have installed on the computer. Momentarily the software begins to download directly to your computer system.
Double-click the downloaded software to load the installation wizard. Click "Next" on the welcome page, then accept the end-user agreement and leave the current installation name and location as-is.
Select "Install" to install the software directly onto the computer system.
Plug the USB data cable into the power connection port on the Samsung L760, then plug the other end of the cable into a USB port on your computer.
Load the software you just installed; the computer automatically detects the hooked-up cell phone.
hope this helps
Sep 13, 2012 | Samsung Computers & Internet
Hoe to I get my hp 12c calculator to show the begin/end format? It did, now when o hit "g" "7" beg or "g" "*' end, can not get to display? Thank you !
Begin mode is obtained by pressing [g][7] and it should then show BEGIN in the bottom line of the display. End mode is obtained by pressing [g][8]. End mode does not not show an indicator in the display because it is the default mode, so if BEGIN isn't showing, then the calulator is in End mode.
Mar 18, 2011 | HP 12c Calculator
How do you get rid of begin setting
To change the payment mode from BEGIN to END, press g [END] (END is on the 8 key).
To change it back to BEGIN, press g [BEGIN] (the 7 key).
Feb 22, 2011 | HP 12c Calculator
I NEED TO REPLACE CV BOOT ON MY 2004 GRAND CHEROKEE WHAT SHOUL I DO FIRST
First, I don't recommend replacing the boot unless you know exactly when it split (such as off roading yesterday) Dirt gets into the joint and even if cleaned they become unreliable. (You can get a remanufactured complete axle assembly or a scrapyard unit at reasonable cost.
Removal begins with the nut on the axle end. (very tight at about 175 foot lbs). Once that is free, remove the brake claiper and rotor. Next, remove the three twelve point bolts behind the bearing hub.
(I use a sacrificial socket and run the bolts out about half an inch and use a hammer to drive them back in to break the hub free) Once the hub is out, you can pull the axle out of the differential right through the hub opening.
Install is the reverse of removal BUT support the axle when putting it back in as there is a seal deep inside the axle tube next to the gear set. If you drag the axle end, you can knock it out and diff lube will begin to leak from the open end of the tube when you drive.
One tip: when doing these, I generally disconnect the tie rod end from the steering knuckle. It makes it easier to work as then you can turn the assembly from side to side to get at the hub bolts.
Nov 22, 2010 | Jeep Cherokee Cars & Trucks
Need to change the time
You weren't precise if the change was due to Daylight Savings Time or just a general need to change the time so I'm giving you the complete set of instructions for changing the time
Setting the Time
Note: Use 24 hour and 60 minute format when setting the time.
For example: 2:00 pm = 14:00.
1. To make changes to your clock’s time setting, you must first put the clock into Program mode. See
section Accessing Program Mode to Update Calendar, Time and DST for instructions. When the
display flashes P1 dAtE, press the ◄ left button until P2 CL oc appears, then press the ● right
button.
2. Press the ◄ left button to choose 12-hour AM/PM display or 24-hour military time, then press the ●
right button.
3. Press the ◄ left button until the correct hour appears, then press the ● right button.
4. Press the ◄ left button until the correct minutes appear, then press the ● right button.
5. When the display flashes the correct time, press the ● right button.
6. The display flashes P2 CL oc again. To make changes to the DST start date or DST end date, press
the ◄ left button one time until P3 BDLE appears in the display and continue to How to Set the
Begin Date for DST. Otherwise, press the ◄ left button several times until END appears, and select
the ● right button to save your updated settings.
How to Disable DST
To disable Daylight Saving Time, set the DST beginning date equal to the ending date (i.e., DST begin
date = 08-03-09; DST end date = 08-03-09).
See next for details regarding setting the DST begin date and end date. Typically, clocks operating in
Arizona, Hawaii and Puerto Rico do not observe DST, and disabling the DST function typically applies to
those areas only.
By default, and unless otherwise modified, DST takes effect on the first Sunday in April and ends on the
last Sunday in October (this was the United States standard through 2006).
How to Set the Begin Date for DST
Note that in 2007 the standard for DST changes to a different start date and end date. The steps below
correct the change in the new start date for DST. The new start date and end date need only be changed
once, since the clock’s rolling calendar function auto-calculates the start date and end date for DST every
year thereafter.
Note that if the begin date for DST has passed, in addition to modifying the begin date (and end date),
you will also need to modify the time.
1. When the display flashes P1 dAtE (see earlier section Accessing Program Mode to Update
Calendar, Time and DST for instruction), press the ◄ left button until P3 bdLt appears, then press
the ● right button.
2. Press the ◄ left button until the correct year appears, then press the ● right button.
3. Press the ◄ left button until the correct month appears, then press the ● right button.
4. Press the ◄ left button until the correct date appears, then press the ● right button.
5. When the display flashes the correct year, month and date, press the ● right button.
6. When the display flashes P3 bdLt, press the ◄ left button once to select next menu option, P4
EdLt, which provides a way to set the end date of the Daylight Saving period.
Setting Daylight Savings Time for model PIX-10/15/21
Page 4 of 4
How to Set the End Date for DST
correct the change in the new end date for DST. The new start date and end date need only be changed
year thereafter.
1. When the display flashes P4 EdLt (see conclusion of previous section How to Set the Begin Date
for DST for instruction), press the ● right button.
6. The display flashes P4 EdLt again. Press the ◄ left button several times until END appears, and
select the ● right button to save your updated settings.
Note: To disable the Daylight Saving Setting, set the beginning and ending date to the same date.
Apr 16, 2009 | Office Equipment & Supplies
Can any one figure out code for this pseudocode?????
its the psuedo code for a function in some sort of word processing application. basically it looks for a word, noun , phrase or period. and record the position then adds it to a table.. Proberally home work for a programmer i guess.
Feb 20, 2008 | Computers & Internet
Open Questions:
2K Games Sid Meier's Civilization V for Windows Logo
100 people viewed this question
Top 2K Games Video Game Consoles & Games Experts
rhodesworks
Kith
Kith
Are you a 2K Games Video Game Console and Game Expert? Answer questions, earn points and help others
