I had changed my voice mail last week because I was out of min. So have been trying to change it again back to what it was. I am getting an error that it can not re-trive my current voice mail and it takes about 5 min for that error to come up. So I put it on "default" and pressed save and it will not save. When I put it on custom........it will not record. HELP!
SOURCE: IPhone voicemail doesn't work?
call 611 from the phone you can press I think option 1 then option 3 you should be able to reset your voicemail pwd. however before you do that you should call your phone from another phone not just press 1 send. by calling your phone it will let you know if you have a voicemail box actually setup porperly.
SOURCE: Problem setting up voicemail
Check the procedure is correct.
1 Tap Voicemail, tap Greeting, then tap Custom.
2 Tap Record when you’re ready to start.
3 When you finish, tap Stop. To review, tap Play.
To rerecord, repeat steps 2 and 3.
4 Tap Save.
Hope this helps
Regards
SOURCE: iphone touch screen not working
hey meybe a software that you install in your iphone is that one causing it, try to un install some, and maybe theres not enought space for your iphone, try to delete some.hope it solved your problem.
Testimonial: "solution provided by u is on right lines though not fully helpful. I guess software got corrupted or there is some virus in it"
SOURCE: error -70001 problem changing dvd drives region
when changing the dvd region for the fifth and final time. you need to insert a disc which only plays one region (the one you want) in my case region 2. if the disc can play more than one region then it wont set.
SOURCE: changing sim in iphone cause overheating and rapid battery drain
it is the sim card brother not the charging jack k you must upgrade your iphone version to use the simcard again and prevent rapid battery drain k. or you can change sim either. k
