The power went off during storm. Came back on and I was setting the time I accidentally hit the self clean button so by instinct I opened the oven door before it could self lock. Well about the same time another power surge hit and knocked the power off again. the door latch at this point is about half out half in. I can open and close the door without problems, but the latch is stuck half way and the oven door is not closing all the way. I can't self clean because it says to close the door and I cant use the oven because it's in self clean mode! I have flipped the breaker and left it off for 1 hour still no reset? don't know what to do now can u help?
SOURCE: self clean inoperative
Dear Superglide, An error code "F5 E1" means "door latch not operating". In such situation I would recomend to replace the oven lock assy (part # 9782611 ) which is located on the back panel.If you are going to do it yourself - DO NOT forget to unplug the power cord first. About service manual - try to call Kitchen Aid directly.
SOURCE: KitchenAid convection oven - panel went black during self-clean SOS
turn power off. take back off range. manually unlock door. it sounds like your control panel is shot.after you have it unlocked turn power on try your oven
SOURCE: Kitchen Aid Double Convection Oven stopped during Self Cleaning
same thing happened to me yesterday took all day to figure it out was the themal fuse on the back of the oven the part number for my kitchen aid is 8300802 if you want the doors to unlock and reset the display you can take the leads off the fuse touch them together and the door will unlock however it is best to change the part took me 5 minutes once i knew what to look for
you have to remove the back panel and you will see the part with the number on it cost me 50 dollars but better than the 8o bucks to have a sevice guy come and do it next time i self clean i will pull the stove away from the wall to help keep it from ver heating
SOURCE: Ran Self Cleaning - Display went blank & Oven Door stayed locked
You need thermostat limiter #8300802. It is on the back of the stove behind some sheet metal towards the top. With shipping this part is about $39.00. But don't waste your money. If you replace it, it will burn out again! I am currently trying to find a way for either a class action lawsuit or a total recall. Kitchenaid/Whirpool is well aware of this problem. A $1500.00 stove and it won't self clean.
SOURCE: Door locked: display panel not lit.
Unplug the appliance and the next day it will work again. Do not use the self clean cycle or I will have to spank you! Did you not know that 900 degrees for 3 hours can harm delicate expensive electronics. Get some easy off and clean that oven or get ready to spend some serious dough on fixing this puppy down the line.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
