I found this online for you.
Possible causes for this check engine light code include:
Blown oxygen sensor fuse
Open circuit in oxygen sensor harness
Open circuit internal to oxygen sensor
Open circuit in PCM
Short circuit in oxygen sensor harness
Short circuit internal to oxygen sensor
Short circuit internal to PCM
Diagnostic Help: To diagnose a P0061 check engine light code we will need to test out the oxygen sensor wiring and also test the circuits through the oxygen sensor itself. The internal processor circuits are a possible cause but are much less likely, so the other areas are thoroughly
tested first. See our article
Automotive Circuit Testing 101, if you need more assistance with this. If concern is determined to be intermittent, check out our article on
Intermittent Diagnosis and wiggle test connectors and wiring, attempting to duplicate concern. You may also use the "Get Help" link if you need specifications or have any other related questions. Remember to refer to an appropriate manual for specific instruction.
