Question about Bunn VPR Coffee Maker
Bunn leaking out of vent - Bunn VPR Coffee Maker
Bad leaking bunn commerical VPR pour-omatic
You will need to replace it, parts are not made for repair except under warranty.
Nov 30, 2016 | Bunn Coffee Makers & Espresso Machines
My Bunn coffee maker leaks out of the bottom
If you will call Bunn Customer Service, there is a seal kit that can be sent out to fix the leaking problem you are experiencing.
Jun 01, 2010 | Bunn 10 Cup Home Coffee Brewer
Bunn code date 145000 water leak took apart need
If you will call customer service, a seal repair kit can be sent to you which is successful 90-95 percent of the time in fixing the leak problem.
Mar 25, 2010 | Bunn 10 Cup Home Coffee Brewer
Bunn coffee brewer leaking
Is this a lot of water, or just a small amount.
As the unit sits over time and runs heating cycles, it may have some vapor come out of the vents. That will cool and collect around the unit.
try turning the unit off for the weekends. If you still have water around the unit, then it may have a leak in the tank.
Nov 11, 2009 | Bunn VPS Coffee Maker
Bunn coffee maker leaks all over the counter. What
there's probably a 'silicon rubber' hose that feeds hot water to the 'grounds basket'- it may be loose, or damaged. is it leaking water, or coffee?? we have a bunn 8-cup, which has a pre-heated water tank that brews a pot in about 3 min. energy waster, but when you need coffee, you need coffee!!! is your filter holder properly centered? is the carafe lid hole clean and un-obstructed?
if it's leaking water, and not too costly to replace- you may consider replacing it with a new one!
good luck!
Oct 09, 2009 | Bunn GRX-B Original 10-Cup Home Coffee...
Leaking a half cup of water from the bottom while brewing
Call bunn for replacement gasket free of charge per recall.
Jul 13, 2009 | Bunn 10 Cup Home Coffee Brewer
MY BUNN COFFEE MAKER LEAKES WATER
Yes Bunn will send you a repair kit free of charge. Just apply a bead of silicon below the rubber gasket before you tighten it down and it will solve the problem.
Mar 16, 2009 | Wega Mininova EPU Espresso Machine
Bunn Coffee Pot Leaks Water
I obtained Bunn washer seal repair kit from buy-it-now-store.com for $6 plus $7 S&H and it solved the problem.
Mar 06, 2009 | Bunn NHB Coffee Maker
Bunn (Pour Omatic) coffee maker has been leaking water - what would couse it to leak? Thank you
When a machine leaks, it is generally an indication of a bad seal or gasket. If you will call Customer Service at 800-352-2866 with the model and date code we will be happy to help you resolve your issue.
Oct 28, 2008 | Bunn NHB Coffee Maker
Bunn VPR Coffee Maker Logo
85 people viewed this question
Top Bunn Coffee Makers & Espresso Machines Experts
Kelley Hopper
gbob59
Marvin
Marvin
Are you a Bunn Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
