Harman Kardon FL8350 5-Disc CD Changer Logo
A
Anonymous Posted on Apr 12, 2014
Changer has a cd in 5 of 5 slots but changer will not play 4 disc slot
Won't play any disc on any of the 5 slots boom box also has casette player that records
Laser is either dirty, so a lense cleaning disc required. Or the cd transport is kaput. Uneconomical to repair if this is the case
1helpful
2answers
We can't get the factory 6 disc cd player to load more than 1 disc. What is the sequence for loading additional discs?
The following is the owner's manual for your 2004 Dodge Neon:
http://www.dodge.com/en/owners/manuals/index.html?year=2004&nameplate=Neon
P.99 describes how to load discs:
1. Select and press any numbered button without an illuminated light above it.
2. Insert the CD while the light above the chosen button is flashing and the two lights on either side of the slot are illuminated.
3. Upon insertion, the CD will begin to play, and both the button light and the lights in the corner of the loading slot will illuminate.
4. Repeat the process for loading any additional CDs. The CD playe rwill stop while additional CDs are loaded.
Playing Discs
The radio will show the CD number, the CD track number, and the Track Time Elapsed while the radio is in the CD mode. IF more than one CD is loaded in the changer, the changer will automatically play the next disc after playing the last track of the current disc.
Wow, that's a lot of typing.
I didn't know the 2004 Dodge Neon had such a nice changer.
Good luck.
Kenwood CD-203 5-Disc CD Changer will not play CDs. It powers up and recognizes a CD within the slot, but it does not read the disc to begin playing.
The laser might be the culpert, be sure its clean by using a swab and a alcohol. If the laser is needed
it could cost approx $75 unless their using a Sony
which might be cheaper!
2answers
I have a Bose Wave Music System with add-on 4 cd changer attached. The top portion (radio & 1-cd function) is working fine. The 4 cd changer is not working, I keep getting an error message and none of...
Bose does not release their schematics or parts lists, effectively making themselves the only repair center for their products. Your only safe repair method is to contact the service/repair center at www.bose.com. They will likely offer you a flat rate repair or credit towards the purchase of a new unit.
The unit rarely plays CD's anymore. It spins the
most likely a bad laser lens or out of adjustment.
No play
Sounds like the drive belt that spins the disk is slipping or broken. You have only one actual cd reader so no matter what slot the disc is in it has to go to the same cd reader drive.
Hope this helps...
4helpful
Doesn't recornize Cd's and won't play cds
I have a AWM-2700U (3 disc changer) that was doing the same thing. I removed the cover and found that the laser lens for the CD player had come out of it "slot". I cleaned it with alcohol and a cotton swab and replaced it in the slot and it has worked for the past 3 months since. Hope it works for you.
2answers
Harman Kardon FL8350 CD Changer
try lifting the left side of the player, I tried that last night, and it behaves different, in horizontal mode it tries to load each disc before it finds that there is no disc, but when tilted it just scans the slot (with som optical sensor) and finds the slot empty without loading the disc
Top Harman Kardon Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
Sean Wright
Sean Wright
Are you a Harman Kardon Audio Player and Recorder Expert? Answer questions, earn points and help others
