Question about Razor USA Razor Dune Buggy
Razor dune buggy won't work - Razor USA Razor Dune Buggy
1 Related Answer
shelley_mccu
shelley_mccu
SOURCE: Razor Dune Buggy Problem
I have the same issue with mine. Batterys check out fine.. i'm starting to suspect the motor??
Posted on Aug 18, 2012
Fisher price power wheels dune buggy will not work when put in the forward gear but it will work in the reverse gear
check to see if both wheels are spinning in reverse, if not one of the motors is bad or disconnected and this will affect the forward gears
Feb 04, 2013 | Toys
Dune buggy won't start. Very weak spark
Did you check out the rotor and distributor cap?
Jan 13, 2013 | Cars & Trucks
Jul 23, 2012 | Razor USA Razor Dune Buggy
My razor dune buggy won't drive
are you sure that the charger is putting out enough volts to charge the batteries? check the charger with a multimeter, then check the batteries with a multimeter, and viually inspect the batteries for bulging
Apr 28, 2012 | Razor Dune Runner 350 Go Cart
How can i get the instructions for the mega Mega Bloks Pro Builder Dune Racer Buggy 9763 i dont have the instructions
You can find the instructions for this Mega Bloks set and loads of others at the Mega Bloks wiki - Blok City
If you follow the link below and then go to the bottom of the page you'll find the instructions for the Probuilder Dune Buggy
http://www.blokcity.com/wiki/index.php?title=9763_Dune_Racer
Sep 23, 2010 | Mega Bloks ProBuilder Leopard 2 Tank
Buggy is removing charge from battery
try investing in a battery charger instead of replacing the battery the dune buggy probably doesn't have an altinater to recharge the battery
Apr 18, 2010 | Jeep 36 Volt Battery for Minimoto ATV, Go...
Unknown make of engine
generally the dune buggy was made by a volkswagen chassis and engines
Apr 15, 2009 | 2006 Toyota Camry
Can not get power to my pyle amplifier
Usually On Car Amplifiers, there is a Connector/Wire called "Remote On".
This is where Headunit supplies 12V to trigger the Power on the Amplifier.
(Of course, head unit usually has Remote Wire also in order to turn the Amplifier on).
If this wire is properly connected and still does not turn on, then try to supply 12V directly from the battery. If it turns on then your head unit has problem, If it does not turn on then your Amplifier has problem.
Jan 27, 2009 | Pyle Audio Players & Recorders
Razor USA Razor Dune Buggy Logo
Top Razor USA Toys Experts
Marvin
Marvin
Tom Chichester
ray gallant
Are you a Razor USA Toy Expert? Answer questions, earn points and help others
