Question about Canon PowerShot SD1000 Digital Camera
Black screen displayed, while recording movie only sound is recording no picture is recorded. While taking photo, nothin is displayed on the screen
5 Related Answers
poolseman
zdenek vajdak
  • 206 Answers
SOURCE: PICTURE SCREEN
CCD sensor fault : playback fine but no image in capture mode. Replace the sensor. Canon repairs thse faults free of charge but you need to find out what their policy is with A85. As I said this is a classic : I get + - 5 A85s every week with this particular fault.
Posted on Sep 14, 2007
t00nz
CameraR
  • 4738 Answers
SOURCE: black display
This sounds like it might be a defective CCD imager. If so, Canon should fix this for you for free, including free shipping both ways. This is regardless of your camera's warranty status. Please check the following two links for more info:
http://camerarepair.blogspot.com/2007/11/canon-digital-cameras-showing-black.html
http://www.usa.canon.com/consumer/controller?act=PgComSmModDisplayAct&fcategoryid=225&modelid=13390&keycode=2112&id=29819
Applicable cameras include:
A40, A60, A70, A75, A80, A85, A95, A300, A310, S1 IS, S60, S200, S230, S330, S400, S410, S500, SD100, SD110, IXUS V2/300/400/430/500, IXY Digital 200a/300a/400/450/500
Posted on Mar 25, 2008
Anonymous
  • 46 Answers
SOURCE: Black screen in shoot mode
The most common cause of this is a failed image sensor. Usually the playback mode will let you view pictures taken before the issue happened just fine and you will also be able to view the menu system just fine. When viewing the screen in an image taking mode, however, there is typically discolorations, horizontal or vertical lines, image bluring or distortions, or simply a black screen.
This situation, if caused by the image sensor, has to serviced and cannot be fixed by the user. If you are within your one year warranty and no user damage has been done to the camera, the camera will be fixed at no charge. If beyond the 12 month period however the customer may opt to have the unit repaired at a cost or take advantage of the Canon Loyalty Program and upgrade to refurbished S3 IS at an alternate discounted price.
Hope this helps.
Sincerely,
HeavyDLB
Posted on Jun 01, 2008
Anonymous
  • 411 Answers
SOURCE: no image appears in viewfinder screen
shutter is not fuctionong shutter unit to be serviced /replaced with a new unit
Posted on Feb 28, 2010
t00nz
CameraR
  • 4738 Answers
SOURCE: Camera not displaying images as seen through
A stuck shutter is another common failure mode for digital cameras, particularly for the SD1000. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, sometimes with lines, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
By the way, my wife's SD1000 also has this problem every once in a while. I easily fix it by using the following steps from the link: powering on the camera, opening and closing the battery door, and flicking the end of the lens barrel with my fingertip (or you can tap it with a pencil as discussed in the link).
Posted on Jun 19, 2011
L820: Display dead in most functions, but not all
I would hope you have tried removing the battery, charging it and replacing it first already. The next thing I would try is to set the camera to factory default options.
Dec 04, 2013 | Nikon COOLPIX L820 Digital Camera Black
Display dead in most, but nbot all functions
While a cable is connected to many Nikon cameras the screen shuts down.
Sep 22, 2017 | Nikon COOLPIX Cameras
Display dead on most functions, but not all
The display is ALWAYS dead as long as a cable is attached. To make it work again disconnect the came and cycle power on the camera.
Sep 21, 2017 | Nikon COOLPIX L820 Digital Camera Black
Cannon powershot s3is turn on to take pictures and the led screen is black cant take pictures everything else works
this is a normal occurrrence in devices containing CCDs and does not constitutes a bad functions. (tHIS image will not be recorded when still photo, but it will be recorded when shooting movies.
Remember the in the LCD monitor will darken in strong SUNLIGHT or bright light.
Sep 22, 2012 | Cannon Cameras
Turn on s3is cannon power shot to take pictures and the led screen is black cant take pictures
The image in the LCD monitor will darkn in strong SUNLIGHT. This is normal, is not constitute a badfunction. This iamge will not recorded when shooting still photos, but it will be recorded when shooting movies.Read your owner manual section troubleshooting
God bless you
Sep 22, 2012 | Canon PowerShot S3 IS Digital Camera
LCD Display is Black
the image in the LCD monitor will darken in strong sunlight or bright light. This is normal occurrrence in device CCDs and does not contitute a malfunction. This image will not be recoded when shooting still photos, but it will be recorded wihen shooting movies.Read you owner manual and adjust the MENU, according with your o. manual.Otherwise you must go the repair shop
God bless you
Jul 31, 2012 | Canon Cameras
Sony F55 Recorded Display
The filename (e.g. DSC0012.jpg) shows the image number, the filespec shows the date and time recorded. Most software will give you document info about resolution of the image. I wouldn't worry about what the battery status was when the shot was taken or how many other images were on the Mstick. I guess I'm not sure what you need.
Sep 11, 2005 | Sony Cyber-Shot DSC-F55 Digital Camera
Black bars in the picture
For Models: CC4352, CC4362, CC4393. Your camcorder has a wide format recording mode that lets you make recordings compatible with the 16x9 format. When 16x9 is activated, the camcorder records black bars at the top and bottom of the picture to produce the wide-screen (movie) effect. This is also known as "letterbox" recording. Do not use this mode unless you have a compatible 16x9 TV. When played on a regular TV, black bars appear on the screen. If the 16x9 feature is activated on your camcorder and you want to turn it off, press REC/PAUSE to pause recording, and repeatedly press DIGITAL EFFECTS until no digital effects display appears.
Sep 06, 2005 | RCA CC-432 Camcorder
E-mail images
What is the Macro function used for? The Macro function allows you to take close-up pictures. Use the Macro mode when you are 8.4” to 19.2” away from your subject. Where is the Reference Manual for the D-390? The Reference Manual is located on the Camedia Master CD-ROM and is available in four languages (English, French, Spanish, and German. The manual can be viewed on your computer screen or printed on your printer. How can I get traditional photo prints from my digital camera? Most photo processing centers or digital printing Kiosks can make traditional photo prints from a digital camera. There are also many on-line photo processors which conveniently deliver prints by mail. You can also make prints yourself if you have a photo quality printer like the Olympus P-400 printer. Why are there so many quality settings? Different quality settings are used for different purposes; for example, lower quality settings can be used to e-mail pictures because of its small file size. Higher quality settings are used for printing photo quality images. What settings should I use to get the best picture quality? The best picture quality setting on the D-390 is SHQ (Super High Quality). The SHQ file is the largest of all four quality settings. The image file size is approximately 786K. What is the video output used for? The video output is used for viewing images from your camera to a TV. A slideshow can be accomplished by using the camera hooked to the TV or recorded from a VCR. When taking macro images, can I use the viewfinder? Since the viewfinder sees the subject different than the picture taking lens, we recommend using the LCD monitor screen for taking macro pictures. The image previewed on the LCD monitor will be the exact image that is taken. How do I make a Panorama picture? You can easily make panorama pictures with your D-390 by “stitching” together multiple pictures. First, activate the panorama mode on the camera by selecting Mode Menu - Camera - Panorama. Take your pictures while making sure to overlap the edges of the images. Download your pictures to a computer and then use the “Panorama” function in Camedia Master to stitch them together. For more detailed information, please refer to the camera documentation. What is movie mode function? The movie mode function allows you to record short movie clips. The recorded movies can be played back or stored as still images using the cameras index function. Please note that the D-390 does not record sound in the movie mode. Can I add sound to a movie made with my D-390? The D-390 does not record sound in the movie mode. What is the best way to e-mail images? E-mailing pictures that were taken with your camera is as easy as attaching a file to your message.
Aug 31, 2005 | Olympus Camedia D-390 Digital Camera
Canon PowerShot SD1000 Digital Camera Logo
Top Canon Cameras Experts
old marine
old marine
halotheracer
halotheracer
Steven Wander
Steven Wander
Are you a Canon Camera Expert? Answer questions, earn points and help others
