Question about Magic Chef MCBR360S Stainless Steel Compact Refrigerator
MCBR360S MAGIC CHEF FRIDGE COMPRESSOR GETS VERY HOT
AND DOES NOT COOL INSIDE
5 Related Answers
Sea Breeze
John Tripp
  • 4656 Answers
SOURCE: Magic Chef Mini-Fridge not Working, Model # MCBR360S
Unplug and look for the thermostat control. Try jumping the thermostat wires together. If it runs then replace the thermostat. Also feel the compressor to see if running, they run very silently. Thanks, Sea Breeze
Posted on Apr 27, 2009
Anonymous
  • 72 Answers
SOURCE: Magic Chef MCBR1000w stopped cooling
If the compressor runs on 120 volts AC, (some are three phase DC, you can use a 3n1 hard start kit, they are very simple to use and cost around $20 dollars, you can purchase them at HVAC supply stores. If the compressor continues to short cycle after installing the hard start kit, then you need the compressor replaced and should check your warranty, this is often an expensive repair.
Posted on Jun 15, 2009
woodchuck789
Charles T Nevin
  • 4070 Answers
SOURCE: Is there a replacement part for the freezer
The evaporator can be replaced and a damaged line can be repaired. It's not cheap as a qualified tech will have to recharge the system besides the repair. With the proper model number you can look up parts here. http://www.searspartsdirect.com/partsdirect/index.action?psid=26129238&sid=PSx20071217x00001a Model number help here. http://www.appliancepartspros.com/modelnumber_locator.aspx
Posted on Aug 22, 2009
SOURCE: Fridge won't start, tries to but clicks off after a few seconds
compressor is broken if you are under warranty you can get it replaced. if not you should buy another one cause compressors are expensive to replace. costs about the price of a new refrigerator. you can try getting a used one from classifieds or craigslist.com
Posted on Aug 26, 2009
Sea Breeze
John Tripp
  • 4656 Answers
SOURCE: my mini fridge will not work. compressor is hot.
Believe you need to change the start relay and overload, Sea Breeze
Posted on Aug 27, 2009
Magic Chef Fridge & freezer not cold-both fans running-Compressor hot- cleaned drain tube-outside of fridg cold
Is compressor running continuously or is it clicking on and off every couple minutes? Is there any frost buildup on inside back wall of freezer?
Sep 26, 2017 | Magic Chef Refrigerators
Fridge won't cool
then its not a fridge its a cupboard,
Mar 23, 2013 | Magic Chef MCBR360S Stainless Steel...
MCBR360S doesn't get cold popping sound and compressor stopped working
Unplug the unit, then remove the relay from the compressor and shake it. If it rattles, then it is bad and needs to be replaced. Here is a like to the new relay.
Oct 18, 2012 | Magic Chef Refrigerators
Door open all night, compressor hot
replace the ptc overload/relay on the compressor this will fix your problem
May 27, 2012 | Magic Chef MCBR360S Stainless Steel...
Aug 26, 2009 | Magic Chef MCBR440 Compact Refrigerator
Apr 27, 2009 | Magic Chef MCBR440 Compact Refrigerator
Magic Chef MCBR360S Stainless Steel Compact Refrigerator Logo
201 people viewed this question
Top Magic Chef Refrigerators Experts
John Tripp
John Tripp
Marvin
Marvin
Lawrence Oravetz
Are you a Magic Chef Refrigerator Expert? Answer questions, earn points and help others
