Question about Juicers
Gnc model hl2098 juicer stop working - Juicers
1 Related Answer
eyeintheskky
Frank Topel
  • 121 Answers
SOURCE: I need to replace the micro mesh filter for the GNC juicer model HL2098, where can I buy it ? Fernando Quesada [email protected]
Either call GNC or go to their store.
Posted on Dec 03, 2014
Champion juicer model G5-NG-853S stopped working. Do you have a repair facility somewhere in central Florida? Are there any warranties for this juicer?
FIXYA is not a manufacturer or seller of juicers.
You need to search elsewhere for assistance with repair or warranty replacement.
Mar 28, 2018 | Champion Juicers
Why does juicer not start when assembled and plugged in?
It has a 10 year warranty, but check the instructions as there are bound to be safety features on it to stop it working unless properly locked together.
Omega BMJ330 Commercial 350 Watt Stainless Steel Pulp Ejection Juicer...
Review
Omega BMJ330 Review JuicerReviewsDirect com
Manual is here. Doesn't look as if there are any safety interlocks in the drawings. Aha, there is a safety lock! It is good to read to the end :>) Page 23 states;
IF YOUR JUICER ISN'T WORKING
If the latch arm on the right side is not secure and properly in place the juicer's safety switch will not engage. Therefore, the juicer will not work. Assemble the juicer properly.
https://www.omegajuicers.com/media/manuals/EFS_BMJ330_390_Manual_JUNE2014_web.pdf
Aug 22, 2014 | Omega Juicers BMJ330
Juicer stopped working
It sounds like a warranty issue if you bought it new. I checked the internet and this seems to be a budget juicer. I had the Jack La Lane model and fortunately the base unit (motor) was replaceable, however I concluded it was such because it wasn't heavy duty and they made money off it failing after a year. These are my personal feelings that you should look at a better model and of course you will pay more for the quality.
Mar 20, 2014 | Hamilton Beach 67800 HealthSmart Juice...
My B& D juicer stopped working after juicing oranges. Is there a reset button?
If you know your model number you can search for the Use and Care Manual here:
http://useandcaremanuals.com/SearchManuals.aspx?SiteID=4
The manual should state whether there is a reset button.
If you need help searching for the manual reply with your model number.
Dec 06, 2010 | Black & Decker Juicers
My champion juicer just stopped working. Makes no sound at all when I flip the switch. Any ideas?
Championjuicer.com sells replacement switches. Order the oil seal and o-ring too to save on shipping. Newer models have a safety cut off that does not allow the juicer to turn on unless all parts are properly positioned.
Oct 25, 2010 | Champion G5NG853S Household Juice...
Jak lalanne not working
Regarding Jack Lalanne juicer. After making sure nothing clogs the blades., make sure the stainless bar is on the correct slots on top of the juicer, left and right. It has a safety switch that when its not closed properly, it won't run.
Jan 31, 2009 | Jack Lalanne Power Juicer 250 Watts
Need Power Juicer manual
If you go onto the website powerjuicer.com scroll down to the bottom of the screen and click on customer care. You can then select the option Power Juicier Manuals and select the model you have and print it. Hope that helps!
Nov 09, 2008 | Jack Lalanne Power Juicer 250 Watts
Fuse may be blown. Take off bottom, it is soldered to the circuit board. Unsolder and replace (I use a fuse holder) to make it easier
May 07, 2007 | Breville JE95XL Juicer
Juicers Logo
304 people viewed this question
Top Juicers Experts
Tom Chichester
ray gallant
Bill Boyd
Are you a Juicer Expert? Answer questions, earn points and help others
