Question about Dometic Rooftop RV Air Conditioner
A/c want shut off.
We set the a/c on 72 or whatever and the a/c never shuts off. The auto shut off want kick off.
william simpson
    Genius:
  • Dometic Master
  • 1,363 Answers
Thermostat bad or not communicating with relay module.
Posted on Aug 17, 2015
My thermostate will not shut off when the room
Sounds like a bad tstat
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
Jun 21, 2017 | Heating & Cooling
Thermostat set at 72 degrees on auto cool setting
Check the tstat's for a relative humidity setting. If it has that option set it to 60 percent. If not, make sure to check all programs if it's programmable. If not those 2 options, it may need to be replaced.
Oct 21, 2017 | Heating & Cooling
My thermostate will not shut off when the room temperature drops to 72 degrees in which my thermostat was set at on the auto cool setting. It even continues to run and drop below 72 to 68 degrees and never...
What brand and installed in what? If a thermostat is installed on a wall that is heated by the sun it will give false temps. If it's mounted too low or high it will not be right either.
Oct 08, 2014 | Heating & Cooling
I have the carrier infiniti system. When my thermostat reaches the set temperature it doesn't always shut off. I shut off the main control to let it reset. It works for a while and then it starts
Carrier Infinity system is a variable speed unit that will just slow down as it approaches set point. Unless it overshoots the set temperature (you have it set on 72 and the temperature keeps rising above 72) this just sounds like normal operation.
Nov 13, 2012 | Heating & Cooling
When gets to temp. shuts off and few mins later kicks back on it keeps doing this
make shur that the thermostat is not above the a heat sourse also some of the t-stats have a ajustment in them that allow you to change the on off zone for e.g. you set it to come on at 72 and it shuts off at 76, the more hight end modles are the ones that allow to to do that
Feb 24, 2011 | Honeywell Heat/Cool Thermostat
My air conditioning unit is cooling properly...but won't shut off
Hello
The location of the thermostat could be a problem,if its too close to a vent it will cut off too soon.
Or if its in a sunny or warm location it may run too long.A 2 or 4 degree swing is not that abnormal.Say if you set it for 74 and you get 72 this is not bad.
If the unit is not shutting off at all,be sure the t stat is set to cool/auto.
If still no luck then you may have a wiring problem or a stuck contactor or bad relay,which would require a service person.
Jun 10, 2010 | Heating & Cooling
Auto shut off has killed my iron
Have you unpluged it ?, it should have reset if you did. You have to keep it moving once in a while or it will kick off again. there is a timer in it to kick it off if left still.
Oct 24, 2009 | Tefal Irons
Does the T8602C1095 have an anticipator that may need adjustment when the temperature set is exceeded, eg we set at 70 and it goes to 71-72 and then need to manually shut down system.
that is how they work. ther is a 1 to 3 degree variance up or down.it probaly does not kick back until 67 or68 degrees. a two stage furnace will keep a more steady temp.
Oct 01, 2009 | Honeywell Electronic Programmable...
Shut off itself
sounds like you might have an auto overvoltage shutdown circuit kicking in. The hivoltage goes to high and the monitoring circuit auto shuts down. More than likely trouble is in hivoltage circuitry. If you have a transformer that will allow you to bring up the set slowly without shutting down and you can look to see what's happening.
Feb 16, 2009 | Sharp 25R-S100 25" TV
I have a Honewell CM921/927 wireless programmable room thermostat that is operating the combi boiler in AUTO mode even when the time setting is meant to be off (no output). The target temp is 20 deg and...
If the room is at the set temperature even when the rad are warm the boiler is doing its job. It takes steel rads up to an hour to cool down so if they stay warm to the touch that is normal.It takes steel rads a long time to heat up when they get cold so its cheaper to let them not get real cold.I was told not to put a programmable thermostat on our boiler simply because it takes a lot of gas to bring your house up even two degrees. I run a non programmable and set our heat at 72 degrees and do not touch it all winter. There should be a water shut off on each rad so if you want your bedroom cooler just shut that shut off on that rad off.
Apr 10, 2017 | Honeywell Heating & Cooling
Dometic Rooftop RV Air Conditioner Logo
Top Dometic Heating & Cooling Experts
Marvin
Marvin
Sheldon Dedek
Mike
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
