Question about Philips 50P8341 50" Rear Projection Television
Philips 50p8342 I was given this it went through a basement flood and the boards in the bottom have been wet. with power supplied it does nothing, should i even bother or junk it?
Posted by james84 on
Anonymous
    Scholar:
  • 87 Answers
By all means get rid of the set! Even if you spent the time and $ fixing you may have further trouble down the road from corosion. Time to buy a new set. NAME BRAND JAPANEESE ONLY! OH, dont forget to buy the extended warranty.
Posted on Nov 02, 2007
Speed will not adjust. will only run at high speed. treadmill was in a basement that flooded. flood was about two weeks ago. allowing treadmill to dry out
if the board got wet most likely its shot its like dropping your cell phone in water it is not going to work rite or not at all
Mar 10, 2011 | Proform Exercise & Fitness
I had water in my basement, now the dryer does nothing. fuses are good.
There is a controller board that is located on the bottom left of the dryer unit. This board is just over $100 as a replacement from FP. In most cases replacing this will fix the problem although I just replaced one on a gas dryer and it powered on but nothing else worked. The power light came on when plugged in but couldn't turn it off or change the setting from no heat dry. Could of been because no gas was attached but that is a question for another day.
This board will get wet and burn out when there is about 5" of water in the basement.
Jul 01, 2009 | Fisher and Paykel DEGX1 Electric Dryer
Dryer wet due to flooded basement
if it was p[lugged in you might have to replace the circuit board,, they can conduit electricity from one circuit to the other in water
Apr 30, 2009 | Kenmore 62602 Electric Dryer
Bad power supply P/N 313503710471
$495 to repair is good.
The original replacement is $469.75 : 313503710471
Refurbished part is $228.83 : 313503710471
Nov 13, 2008 | Philips 50P8341 50" Rear Projection...
Philips 50p8342 problem
I have tv proyection philips model 50p8342, it is blinking red color on the power switch botton four times and then pause then another four time continuosly.
Aug 15, 2008 | Philips 60P8341 60" Rear Projection...
I HAVE MAGNAVOX 51 IN PROJECTION TV PART #51MP6100D137 MY BASEMENT FLOOD & THE TV WAS VERY WET DRY IT OFF FOR A COUPLE OF DAY & IT DOES EVEN POWER UP IS THERE A VERY SIMPLE WAY OF REPAIRING IT OR...
If it was plugged in youre likely needing the Large signal board to get it up and running again. If it wasnt plugged in it may just be a corrosion issue on some solder joints in the power supply or Large signal board. If you need more help let me know.
Jul 24, 2008 | Televison & Video
RCA 56 inch projection TV
six inches will just reach the bottom of the main cuircit board. Does the units green light flash? there is no reset hutton there is a fuse. but i would suspect if it got wet then something blew
Feb 17, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Repair or replace
If the water in the basement came up high enough to cover the main boards in the projection TV, then I would not even attempt to repair it - the cost of replacing the boards, if available, and the realignment would be as much or more than a new set.
Jul 17, 2007 | Philips 60PP9202 60" Rear Projection...
Philips 50P8341 50" Rear Projection Television Logo
64 people viewed this question
Top Philips Televison & Video Experts
ThaMp3Doctor
ThaMp3Doctor
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
