Question about Rowenta Professional DX8800 Iron
Doesn't heat up...
My Rowenta Professional iron (purchased in 11/97 at Macy's for $100) doesn't heat up. I gently shook the iron to deactivate the auto shut off as suggested in the manual. Is it worth it for me to have it repaired and please confirm where I send it.
Thank you
Donna Y. Baran
[email protected]
Posted by pretti on
  • ramirezj13 Mar 12, 2008
    it doesn't heat up. I shook the iron to deactivate the auto shut off, but it still doesn't heat up. Yellow led blinking only forever.
  • Anonymous Nov 01, 2008
    my rowenta iron doesnt heat up
Anonymous
    Problem Solver:
  • 17 Answers
Authorized Appliance And Repair in St. Louis Mo, works on all model Rowenta Irons.
Posted on Nov 03, 2007
Rowenta Iron doesn't heat up and the Auto-off lamps remains lit. Any clues? Is it the small PC card in the handle? Thanks, Rudy
The problem would be the contact points and setting of the heater! u have to open the iron and check, adjust, and clean the bi-metal thermostat or the heater core!
Jun 14, 2011 | Rowenta Professional DE880 Iron
Rowenta iron will heat up and then shut down. Have to keep plugging and unplugging the iron.
Irons use a potentiometer and thermister to control the heat on the element. One of these components is bad and needs replacing. If the iron's still under warranty, get another one. The cost of service would probably be as much as a new iron, but you could call an appliance repair shop to check.
Mar 12, 2010 | Rowenta Professional DM890 Iron with Auto...
Must hold cord just so or iron will not heat up. Rowenta Professioal DM890, 1 year old.
There should be contact information with the instruction booklet so you can contact Rowenta for repairs.
Mar 02, 2010 | Rowenta Professional DM890 Iron with Auto...
I purchase the Professional Rowanta iron. The
Try using different water...
Here is a tip that will help you with that problem...
My Steam Iron is Leaking Water
http://www.fixya.com/support/r5301301-steam_iron_leaking_water
heatman101
Oct 05, 2009 | Rowenta Professional DM890 Iron with Auto...
My Rowenta iron seems to be scortching my white clothes, the plate is stainless steel but seems to look iridescent
if its a light brown appering on the whites, its just to hot, lower setting. also make sure the plate is clean. the stainless changes colour from heat after a while, this is normal
Aug 08, 2009 | Rowenta Professional DM890 Iron with Auto...
THIRD leaking Rowenta
Try buying a cheap one from wallmart or some similar store. They are not too dear so you can use them until they fail and then buy another cheap one.
Jul 27, 2009 | Rowenta Perfect Iron
I have a Rowenta Pro. Iron, model DE-86.1A with auto shut-off. It sticks on auto shut-off. I have to move it around for it to heat up, as indicated by the sensor light on the top.
I believe that is how the safety feature works.
Once the iron detects no movement for a certain period of time (the iron assumes you have finished ironing) the iron will shut of the heating element.
One you have moved it around, the timer should prevent it from auto shutting down for a period of time.
Jul 22, 2009 | Rowenta Irons
Iron No Longer Heats Up
Recommended solution, gently shake, did not work.
Considering the iron was at a minimum two years old, I decided to purchase another Rowenta. I found the recommended solution documented on a FAQ sheet enclosed with the new iron.
I actually own another Rowenta iron (I now have three) that has the same issue. I will send one iron, the one manufactured in Germany, to a Rowenta Service Center to see if can be repaired - it was the first Rowenta iron I purchased and it provided several good years of service.
Sep 18, 2008 | Rowenta Effective DX1700 Iron with Auto...
Rowenta Effective Iron - Model DX1700-U1 NRB01-01
I just drop it a few times on the floor really hard a few times and then it gets hot again!!!
May 16, 2008 | Rowenta Powerglide DM273 Iron
Not heating
The thermal cutoff device blew and must be replaced. It acts like a fuse when the iron gets too hot. Thay are very
cheap and it would be well worth replacing. Hope this was helpful.
George
Mar 24, 2008 | Rowenta Effective DX1700 Iron with Auto...
Rowenta Professional DX8800 Iron Logo
1,600 people viewed this question
Top Rowenta Irons Experts
Ekse
Kate Henkel
Level 1 Expert
Gil Shultz
Are you a Rowenta Iron Expert? Answer questions, earn points and help others
