SOURCE: How to pair nokia bh-104 with blackberry 9000
Just click below link and read carefully
Bhavin Patel
[email protected]
http://nds1.nokia.com/files/support/apac/phones/guides/Nokia_BH-104_apac_ug_en.pdf
SOURCE: nokia bluetooth BH-104 passcode
The default passcode is 0000, and is set for pairing with a device with the nokia bluetooth.
SOURCE: i have made connection between
Try manual connecting. If you have paired your x3 and BH-503 before, you should have your paired devices. So after you connect manually, the headphones should connect to x3 next time automaticly. :)
SOURCE: How to pair nokia bh-104 with iphone
Ok.. you need to do the following:
1. Turn the headset off.
2. Turn on the Bluetooth on your iPhone (it will automatically start searching for Bluetooth devices)
3. Press and keep pressing the power button on your BH-105 Nokia Headset until you hear two sounds, the first is the one that notify's you that the Headset is turned on, keep pressing and you will hear another sound (like a beep), once you hear that second sound release the power button on the headset and voilaaa... your iPhone detected the Headset... Cheers...
SOURCE: i want to connect my
1 Turn on Bluetooth headset and Blackberry hand-held.2 Enable the Bluetooth radio by going to the options window and clicking on Bluetooth. Click on Enable Bluetooth in that window.3)Add your Bluetooth headset to your Blackberry by clicking on Add Device in the Bluetooth window.4)Find and select the name of your Bluetooth headset from the list that appears. The Blackberry will search for all Bluetooth devices within range, so other devices might show up on the list.5)Click Activate Bluetooth device if you receive a call and the Bluetooth headset does not pick up automatically
