Question about Bunn VPR Coffee Maker
Bunn coffee maker leaks water
At the back of the bunn there is a small hole which is at the bottom of the top part
5 Related Answers
Anonymous
  • 4 Answers
SOURCE: my 10 cup Bunn coffee maker leaks from the top
I have the same problem and I took the coffee maker apart to find out why. It has to do with a leak on a fitting. On mine I found that the fitting where the hole in the black plastic that the water flows through to get into the stainless steel tank needed to be repaired with some silicone sealant to fix the leak. Still making some coffee!
Posted on Oct 15, 2009
SOURCE: My Bunn coffee maker is leaking water
  1. Remove nut and gaskets
  2. Mix small batch of JB Quick (a version of JB Weld)
  3. Spread JB Quick with putty knofe or wide screw driver on bottom and top of degraded plastic around hole
  4. Let dry foe four or five hours (speed us slightly with hair dryer)
  5. Smoothe hard but uneven surface with fine sandpaper
  6. Reassemble
Posted on Oct 28, 2008
advacak
Denny Adams
  • 125 Answers
SOURCE: Bunn Coffee maker leaking out
that needs to go back to bunn for a replacement tank, they will likely only charge you for return shipping
Posted on Dec 14, 2008
Anonymous
  • 34 Answers
SOURCE: my bunn coffee maker is leaking from the top where
you need a new one.
try this link. hope it will help you with your problem.
http://www.coffeemakerwizard.com/4-cup-coffee-makers.html
Posted on Feb 01, 2010
atbsmmom
  • 189 Answers
SOURCE: Bunn coffee maker leaking from underneath the bottom
Please get the model and the date code from the bottom of the machine and contact customer serivce. Depending on the date code, there might be a seal kit available or the machine can be replaced at no cost if 3 years old or less. If it is over 3 years old and the seal kit isn't available, the machine will be replaced at a reduced price.
Posted on May 19, 2010
How to fix a leak on a bunn NHBX coffee maker
The leak is most likely between the water reservoir and the tank. Bunn uses a soft silicone seal for that connection that gets compressed over time and starts to leak water whenever you make a pot of coffee.
It's planned obsolescence. Bunn won't sell you a new seal. So you have to improvise. But it's simple enough to do.
Remove the top cover and the plastic water reservoir right below it. Don't tamper with the little valve that opens when you close the lid.
Look for the seal. It could be stuck to the bottom of the reservoir, or sitting loosely on top of the metal tank. Make sure to preserve its top-to-bottom orientation (don't put it back in upside down).
Apply a narrow bead of clear silicone into the grooved side of the seal. Press the seal gently onto the reservoir, then apply a thin layer to the smooth side.
Re-install the reservoir and reassemble the unit.
Aug 09, 2014 | Bunn NHB Coffee Maker
VPR has a semi-sealed tank that keeps +1 pot of water heated and ready to brew. Pouring in a full pot of cold water will fill the top tray and allow a slow trickle of cold water into the top which forces hot water to over flow into the brew basket. This continues until all the cold water drains into the heater tank. So the brew is matched volume per volume. UNLESS the tank was empty or not filled prior to brewing. Follow the brewing instructions from Bunn (on line for *FREE* download at Bunn.com)
* If it leaks (from the bottom) only when you pour in water. Then your pouring it too fast and over flowing the fill tray. slowdown, watch the level in the tray. do not fill past the lid.
* If it leaks just sitting (not brewing) then there is a hole in the tank. Call for service.
* If it leaks after filling the tray half way. then the top of the tank has a leak, loose, cracked, or missing gasket. There is quite a few gaskets on the lid. Call for service.
* Final; Leaks are always bad around electrical equip. Best to unplug and call for service to be safe.
Aloha, ukeboy57
Jun 17, 2014 | Bunn VPR Coffee Maker
Bunn coffee maker only gives half a pot of coffee
Aloha, ukeboy57
PS, Check the pots in the office. Make sure they are all the same size. Decanters come in 3 sizes; 10 cup, 12 cup (standard), and 3L (3 litters). Check the decanter brand as each brand is a bit different in size. All metal decanters are usually very small (8 cup). What ever size you use, just make sure they are all the same.
Mar 08, 2013 | Bunn VPR Coffee Maker
My 10 cup Bunn coffee maker leaks from the top of the water resevoir, from the right top side and from the back top. It looses aprox. 2 cups of water onto my counter while brewing. What has happened to...
Oct 09, 2009 | Bunn 10 Cup Home Coffee Brewer
Bunn coffee maker leaks all over the counter. What
there's probably a 'silicon rubber' hose that feeds hot water to the 'grounds basket'- it may be loose, or damaged. is it leaking water, or coffee?? we have a bunn 8-cup, which has a pre-heated water tank that brews a pot in about 3 min. energy waster, but when you need coffee, you need coffee!!! is your filter holder properly centered? is the carafe lid hole clean and un-obstructed?
if it's leaking water, and not too costly to replace- you may consider replacing it with a new one!
good luck!
Oct 09, 2009 | Bunn GRX-B Original 10-Cup Home Coffee...
Coffee maker leaks
Please contact customer service and a seal kit can be sent to you that should fix your leak-it is successful about 90-95% of the time.
May 27, 2009 | Bunn-O-Matic Coffee Brewer GRW8
Commercial bunn coffee maker that the water only dribbles out
In addition to running vinegar thru your coffee maker, remove the sprayer at the point where the fresh coffee comes out to enter the carafe. It is a disk about the size of a half dollar with several small holes in it. Use a small piece of wire to clean out each of the holes and you should have the speed back. good luck.
Jan 27, 2009 | Bunn Counter Top Coffee Brewer Commercial
Water leaking
The silicon seal inside the coffee maker tends to disintergrate. Bunn Inc. does not sell parts for the inside of the coffee makers, but a seal kit can be purchased through a small appliance repair center or repaired for a small cost. Kit is about $8.00 at most places.
Oct 24, 2008 | Bunn Cuisinart Coffeemaker: Pour-Omatic...
Dennis Karlen supplies repair parts for this problem. You can find the various kits on his website
http://www.jneuhaus.com/appliance/karlen.html
There are other suppliers who sell two silicon washers and a stainless steel washer in kits, but they tend to run considerably more.
The rubber washer would degrade quickly due to the heat. You may be able to get by with a new silicon washer. Check your local (not national chain but local francisee) hardware store.
Feb 15, 2008 | Bunn GR10 Coffee Maker
Bunn VPR Coffee Maker Logo
119 people viewed this question
Top Bunn Coffee Makers & Espresso Machines Experts
Kelley Hopper
gbob59
Marvin
Marvin
Are you a Bunn Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
