Clarke 56382453 BOS-18 Low Speed Orbital Floor Machine Logo
A
Anonymous Posted on Apr 11, 2014
DISASSEMBLE bASE-ORBITAL FROM MAINFRAME
NEED INSTRUCTIONS TO DISASSEMBLE AND ASSEMBLE BASEPLATE FROM MAINFRAME TO REPLACE SPRINGMOUNT KIT
Thomas Smithbrother
Level 3:
Top Expert:
  • Master 3,698 Answers
  • Posted on Aug 10, 2014
Thomas Smithbrother
Master
Level 3:
Top Expert:
Answers
3698
Questions
0
Helped
956931
Points
10318
I need replacement buffing pads for my Miele floor polisher 4000S. Are they still available?
Any janitorial supply in your town, or ebay. Your Home Depot or Lowe's may have them as well as Amazon.
1helpful
4answers
How to find total floor polishing service provider in Melbourne?
Timber Floor Sanding and Polishing Melbourne
Use this guy, i have used them before & they are very affordable & professionals for sure
1helpful
Our Ultra D.C. Burnisher starts instantly when the cord is plugged in, even before pulling the safety trigger levers. Can you suggest a reason for this?
The switch has gone bad. Very common on these. The contacts in the switch wear out and then get welded together. The motor draws a lot of power when first started and this is ******* the switch.
How to balance tension on the for free motion quilting?
Other than design differences tension settings are much the same.
Check out these videos and you will probably find your answer.
sewing machine tension YouTube
Where can I find a manual for an Electrolux 2101 shampooer?
This is the B-8 model shampooer. I just uploaded it under Electrolux B-8 Shampooer.
HOW TO REPLACE THE POWER CORD
https://www.kenteuroclean.com/service/manualspartslists.aspx
How to wax a hardwood floor using a Electrolux floor cleaner and polisher
There are basically two models, but both are similar in waxing floors. I've just uploaded the manuals for each.
The instructions for the Floor Pro can be found on page 12 of the manual. The B-8, or 2101, is the same.
Basically:
Clean the floor.
Prepare a spray bottle of wax solution.
Spray an area in front of you, and back away while "swinging" the shampooer from side to side. Repeat.until finished.
2answers
Bought 3 metal floor hurricane candle holders for our entryway ($220 each). Blind dog knocked one down and broke glass. Pier ! says they don't have replacement glass holder. Any ideas on where I can find...
These are specially made with to suit the particular requirement and there is no way but to get this replacement from the manufacturer. the other way out is to use the two remaining ones on either sides for a brighter light and use 10" pipes of PVC or transparent tubings to give a special shade. Check this out with the availability at a plumbing store. You can cut portions on the opaque shade and use acrylic pieces to be stuck within to give an art look.
Top Clarke Floor Polishers & Buffers Experts
RAJA NADEEM AKHTER
RAJA NADEEM AKHTER
Are you a Clarke Floor Polisher and Buffer Expert? Answer questions, earn points and help others
