How to replace the developer toner in e-studio 35 copier
SOURCE: toshiba estudio 35
What is the copy count on the machine?
Toshiba copiers have service intervals to replace the drum, cleanerblade, corona wires and developer material.
That could resolve your printing problem.
SOURCE: Toshiba E-Studio 35 PM Kit Instructions
open front door and remove waste toner container, unplug connector and loose blue screw slide out developer unit removed top cover empty developer(100%). then open by-pass, duplex and jam access cover , remove two screws and slide out drum unit .remove charge corona. release latch on rearand remove bracket/bar( on top of drum),turn level counter clockwiseto release slide drum shaft out.remove two screw lift drum blade before install new drum & blade needdust some lubrication powder.after put everything back,hold down05 while turn onthen enter200,press start,let run about 3 minutes ,the value should bebetween 2.35-2.45 press set or interupt key same procedure doing 08then401 set to 0
SOURCE: keeps on coming up with install new toner
It was a e studio 350 not a 232 that I was looking at , but that doesnt matter the problem is the same and it ended being the toner sensor in the dev unit, so I replaced it and now its working fine.
SOURCE: Copier Studio 55 Copier.
Hi how are you this is jack
Dear ,
you copier e-studio 65 showing message dispose of used toner.. ok.. Its donot mean dispose all old toner and install new toner... Its mean dispose used toner box... Dispose toner Box is a seprat box copier all garbage toner droped this box and when this box are full then copier showing message please dispose used toner box... please check it and dispose it.
Thanks
SOURCE: We replace the used toner
There is a sensor just behind the waste toner box that sends beam through the water toner box to see if reaches the other side. If it does not, then the sensor thinks that the box is full. So you need to clean the waste toner box with some liquid cleaner so that it looks white from outside. Once the box is dry, try again. This should work now. Otherwise, there is problem with the sensor.
