This cable you have is only for transferring data from one computer to another. To transfer data to this drive you must do so over the network or by loading your content onto a USB drive then connecting the USB drive up to the USB port on the WD MyCloud and using the MyCloud app to copy the data from the USB drive to the internal storage of the MyCloud drive. See the link below for more information. WD My Cloud Direct USB Transfer and SSH Access
Initially, I thought my USB drive is not properly connected and because of that unable to access data. But, the problem is even after proper insertion of USB drive unable to access data. To overcome such issues, use Remo Recover tool to recover data from corrupt USB drive.
If the hard drive in the IBM laptop is OK then remove the hard drive from this laptop. Connect this hard drive to an USB hard drive adapter then connect the USB adapter with the hard drive into the USB port on the Vaio laptop. The Vaio laptop should see it as an external storage device (if the hard drive is OK). You can then open the various folders and files then copy these to the Vaio laptop
If the laptop cannot boot up then to retrieve your data then remove the hard drive from the laptop and connect it to an USB hard drive adapter. Then plug the adapter into a working computer's USB port. This computer will detect this as an external storage device. You can then click on this device and open the folders and files to copy and backup your data files.
Yes , Flash drive is a good way of saving data from your computer it can also act as a back up of the data from the computer that you can access anytime, by simply connecting it to a USB port of computer. Flash drive can be connected to a computer that has a USB port almost all computer has a a USB port including your computer.
u can use the mobile as mass storage mode without pc suit............just connect them and in mobile screen select mass storage then
after in pc tray the device installed and ready to use will appear then u can access them
if u get the gprs connection! if it is activated mean! you install usb data cable driver to your laptop! then goto control panel->network places->create new connection->click connect to internet->click dail up modem->then ISP name->further setting! first install usb data cable cd correctly in you laptop!
thanking you
i think it will useful to you.....
Go to www.nokia.com
There, search for ur phone.
Download PCSuite.
Install it and connect the phone.
Now you can connect ur phone and access data in it.
