How can i print or copy a paper document on c530dn printer
SOURCE: Lexmark 4270 won't feed paper to print or copy!
In this Case take out the Paper from the Paper Feed Tray........ Unplug the Power Supply from the Printer.......... Remove both the Cartridges from the Printer.......... Now take a size 10 Envelope fold it so that it should become like a thin long strip........ Now Insert that Envelope on the left side corner of the Printer and move it from right to left and left to right as fast as u can for about 10 times.......... Now Insert the Ordinary Papers onto the Printer and insert both the catridges and Turn on the Printer...... Good Luck
SOURCE: The Lexmark c530dn prints fine. Smudging down both sides.
Your problem is caused by 2 worn photoconductor units. If you open the front door like you are changing toner, the photoconductor units will be mounted to the door that swings down. You will see should see four units one for each color, red, blue, yellow and black. If you look at the red and black units the ends will look different than the blue and yellow. The photo units have teflon coating that wears off and causes your proble. The replacement part number is C53030x and you will need 2 of them. Just replace the red and black ones and your printer will be back to normal. If you can't locate them locally, let me know and we can ship them to you.
Buddy
Corporate Computer
www.ccl-la.com
Over 21 year of PC and printer support/service
SOURCE: Lexmark C530DN doesn't print double sided. Printer
its easy to solve the problem ...... check all the printer setting of the working one and put the same in this ....
SOURCE: Hi I have a Lexmark
Try to reset the printer. Unplug the power adapter from the printer.
Wait at least 10 seconds before replugging the power adapter into the printer. When the printer completely boots up, try to make a copy a again. If problem continues where it is partially printing copies or having print quality issues, you may need to update the printer's firmware. Firmware update for the S405 is available at http://bit.ly/s405fw.
