Question about Brother MFC 210C All-In-One InkJet Printer
Will not print
Printer says unable to print.
see troubleshooting and routine maintenance chapter in user guide
problem is i have lost my user guide please help
kind regards k .cleckner
Posted by kenneth cleckner on
  • 14 more comments
  • Anonymous Nov 04, 2007
    says unable to clean ! tried about everything
  • Anonymous Nov 09, 2007
    my printer copies but does not print. I think someone might have deleted rthe file. Any help!!
  • kikilove Nov 12, 2007
    I tried to print and the printer is saying see troubleshooting and routine maintenance chapter in User's guide.
  • Anonymous May 20, 2008
    Unable to print. See troubleshooting in maintenance chapter
  • wo so May 21, 2008
    can't print and indicated see troubleshooting and routine manitenance chapter in user's guide. But I lost my user guide.
  • catalunya Jul 01, 2008
    I can't find the user's guide, machine is referring me to it to sort out the fact that if won't print. can you help, please?
  • Anonymous Jul 04, 2008
    it unable to print
  • machongrapoy Jul 05, 2008
    printer says unable to print.
  • j0ke Jul 05, 2008
    Unable to clean - See troubleshooting and maintenance chapter
  • laelhill Jul 10, 2008
    Printer reading unable to print see troubleshooting and routine maintance in user manual. I don't have the user manual but found online somewhere,where you are suppose to unplug it from the power source. Did that then said change black ink. Did that then it went back to the first error message. I even tried canceling the print job and unplugging the usb cord. What do I do know? Can you help me please.
  • Anonymous Sep 22, 2008
    replaced Black ink because near out of black warning. now cleaning and testing , no black shows up. color test are fine. printing of a black circle is near gray. ( printing a target).
    All color ink prints fine.
  • herodbaby Sep 25, 2008
  • courthouse Sep 30, 2008
    printer says unable to print see troubleshooting and maintenance guide - will not shut off by button
  • dramalover Oct 02, 2008
    unable to print!!
  • Anonymous Mar 31, 2014
    unable to print troubleshooting maintenance chapter in user's guide in brother 9420cn printer
Anonymous
Ok since trying to solve my problem, I stumbled on this site about cleaning a brother 210c.
prior to trying this I switched the old ink back and cleaned the area with alcohol and a tip. I put a paper clip down the little tube/pipe and wiped off the excess on a paper towel.
I've cleaned the black ink 5 times in a row. near the bottom of the page ( on the web site it says clean 4 times)
If no link just cut and paste this - to your web browser window.
http://welcome.solutions.brother.com/BSC/public/eu/eu_ot/en/faq/faq/000000/000700/000035/faq000735_000.html?reg=eu&c=eu_ot&lang=en&prod=mfc210c_all
Still no black printing,,,,,,
Posted on Sep 23, 2008
  • Anonymous Sep 23, 2008
    well still no black printing.......
    but I could see black on mapquest
    and these two sites
    one was for bar codes and the other a target
    http://www.currell.net/barcodes/bar_samp...
    http://makarov.com/graphics/targets/pist...
Anonymous
Yes . all you need to do is dissconnect the printer from the power plug for 2 minutes and plug it back. It will clean itself and voila. It works like magic try it
Posted on Jul 04, 2008
Anonymous
You guys did a great job on my printer mfc 210c !! I took it apart like you told me & cleaned the waistinktank & put it back together & yippee it works great !!
Thanx fix ya guys ! Gene77
Posted on Nov 10, 2007
Mix-it-up
  • 832 Answers
@gene77: read this post here:
http://www.fixya.com/support/t202282-unable_print_unable_int_unable_clean
Posted on Nov 04, 2007
  • Mix-it-up
    Mix-it-up Nov 04, 2007
    @kenny1: Did you read the following post in total?!?!!:
    http://www.fixya.com/support/t240869-pri...
    In case your printer shows up another error code after you have entered the maintanance mode you are invited to post the error code here. I'll try to give you a clou then!
  • listio Sep 02, 2013
    error code "print unable 70"
THE LCD SCREEN SAYS PRINT UNABLE 50 AND SEE TROUBLESHOOTING AND ROUTINE MAINTENANCE CHAPTER IN USERS GUIDE.
Read the users guide and do what they say in the Troubleshooting and Routine Maintence Chapter for the "Print Unable 50" error message.
Mar 29, 2011 | Office Equipment & Supplies
Unable to clean see troubleshooting and routine maintenance chapter in user's guide
unable to init. see troubleshooting and routine maintenance chapter in user's guide - printer: DCP- 115c
Jan 30, 2011 | Brother Multi-Function Center® MFC-215C...
Problem with my printer Brother MFC-240C "Print unable 4F"
Access the internal maintenance mode by pressing the Menu/Set button, then press * 2 8 6 4 within 2 seconds. This should put you in the maintenance mode menu. Enter 80, then scroll down with the arrow down (round) key. You'll find an entry listed as purge count. If number is over 6000, enter 2 7 8 3.
This will reset the purge count value. Then the printer will restart,
try this step by step.without missing any thing. thanks
Jul 13, 2009 | Brother MFC 240C All-In-One InkJet Printer
Will not print
www.brother.com has those user guides by model number..
Jul 27, 2008 | Brother DCP 130C All-In-One InkJet Printer
Will not print
What 2 digit error code does the machine display, too?
May 12, 2008 | Brother DCP 130C All-In-One InkJet Printer
Will not print
I have the same error message “Check the Troubleshooting and Routine Maintenance Chapter in User's Guide" I called customer service for "BROTHER 1-800-284-4329 USA; 1-877-BROTHER for CANADA. The Tech’s and I performed a series of diagnostic test, via the phone but were unable to solve the problem... Brother seem to believe that I have a defected printer head, Brother referred me to a local authorize service agent for Brother. I do have my User's Guide and there is no additional information that I was able to use to resolve this problem. HOW EVER, I am able to get the machine to print by opening the cover and close it as if I had installed ink, or removed a paper jam “SIMPLY OPEN AND CLOSE THE COVER”. I also vacuumed and blew the insides and the outside buttons of the machine with forced air from my vacuum, after all that I still have the same problem. My solution...buy a new machine mine is 32 months old and I probably have ran 15k or more print, fax, and copy jobs.
Some times we need to know when to move on, TIME IS MONEY AND TIME WASTED IS UN-REFUNDABLE.
GOOD LUCK
TG/Ks
Jan 22, 2008 | Brother MFC-3240C All-In-One InkJet...
Will not print
You have a major error, probally head stuffed error 41, to find out your error press menu starte and up 4 times, this may show error if not then input 82 set, error will display.
Post back if need more info
S.
Jan 14, 2008 | Brother MFC-5440CN All-In-One InkJet...
Unable to print, See troubleshooting and general maintenance in User's Guide, however, I do not have a User's Guide! What to do?
unable to print, See troubleshooting and general maintenance in User's Guide, however, I do not have a User's Guide! What to do?
Nov 14, 2007 | Brother MFC 420CN All-In-One InkJet...
Printing
Kenny, read the post and my answer here:
http://www.fixya.com/support/t226406-keep_getting_message_unable_print_see
In case you have another error no. code plz post here again
Nov 01, 2007 | Brother MFC 210C All-In-One InkJet Printer
Brother MFC 210C All-In-One InkJet Printer Logo
464 people viewed this question
CheckitRight
CheckitRight
James Cagle
James Cagle
Jim Keysor
