Question about Zeiss Science & Laboratory
Bulb does not come on
12v 100w bulb, have 8.3v ac at the connector, 0 dc v at the same connector. Fan runs, all others work,.
2 Related Answers
Anonymous
  • 45 Answers
SOURCE: Nikon Optiphot-2
You should start by changing the bulb, even though it looks ok chances are that it's no longer working. Do the same with the fuse if the new bulb doesn't work.
Test that power is reaching the socket with a voltmeter or a multimeter so ensure the wiring is ok with the new fuse. If no power is reaching the bulb socket, then you will need to check the wiring every step of the way.
Posted on Apr 28, 2008
Anonymous
You can purchase a variable power supply that will light this lamp and control its intensity if you determine that the power supply in the microscope is bad. This may be the easiest way to fix the problem. Parts for many older microscopes are no longer available and this is a common way to repair the microscope. It's also a common modification made to many laboratory instruments for research purposes. Carefully check the lampsocket as well. It's common for them to fail and replacement is the only cure. The lamp socket is not expensive.
Posted on May 22, 2008
Trying to reverse polarity to 12 volt bulb sockets 1157 type in order to use LED bulbs in my electric scooter.
all of this work when all you need is the correct LED units
bulbs work which ever way the polarity is and bulb holders (sockets are always positive to the enter with the ground being on the outside)
by reversing the polarity at the battery terminals , other items that require a positive feed only , like the ignition module , converter etc will burn out
Flashers work through a relay and by reversing the polarity the coil used to close the points will not work
Replace all of the units that you have damaged by reversing the polarity and just connect the led 's up as you would a normal bulb
All of the rest is from you very limited knowledge of electrics
Oct 03, 2018 | Cars & Trucks
Elmo st600
The bulb you need is this one:
100W MR16 12V GZ6.35 BASE 64627 HLX OSRAM
You can try to buy it from here:
http://www.atlantalightbulbs.com/ecart/10Expand.asp?ProductCode=ELMO-VPD100ST600ST800#page=description
May 10, 2014 | Office Equipment & Supplies
Hampton Bay Mercer ceiling fan keeps buring out bulbs
Halogen bulbs are a lot hotter than other bulbs and have a much shorter life span. It is the nature of the bulb. You can see about changing just the lighting fixture on the fan or look into getting an LED bulb, they run very cool compared to halogen and last forever.
Nov 26, 2017 | Hampton Bay 24002 Ceiling Fan
Right turn light and rear right tail light is out. Replaced with new bulbs and the lights still will not turn on. Please help.
Either you do not have positive 12 volts or the ground at the bulb holder. With a voltmeter or a 12v tester probe between the two connectors in the bulb holder with the bulb out and tail lights on--
If you do not get anything then probe with one lead --red in the bulb holder (switch the red voltmeter lead between the connections in the bulb holder to get a reading)and the other to a good ground --any bare metal part of vehicle.If you get a reading -that means you do not have ground at the bulb holder.
If still nothing--than it means you do not have 12v at the bulb holder. Than try finding a good 12v and work from that a reference point. Confusing? may have to have it checked out
Just in case try a bulb that you know that works..
Nov 27, 2009 | 2006 Dodge Dakota
How to check high power amps by using bulb series technic
You can use CFL (Compact Flourescent Lamps)
100W CFL is cooler and brighter than the standard 100w bulb. Therefore, for the same performance, a 60W CFL is equivalent to the
100W bulb.
Sep 22, 2009 | Audio Players & Recorders
Conecting to 120 volts AC
If you want to get more precise, figure out everything in terms of power (watts).
Basic electrical rule 1, 2 and 3:
voltage x current = power
or re-arranged:
current = power divided by voltage
or re-arranged:
voltage = power divided by current
For example, 12V X 2 amps = 24 watts.
or another example, 400 watts divided by 120 Volts = 3.33 amps
A 55W headlight that uses 12V would draw 55 /12 = 4.6 amps @ 12V
A 55 watt light bulb in a lamp at home would draw 55 / 120 = 0.46 amps @ 120V
As the previous post mentioned, inverters are not perfect when convertering 12V into 120V. If the converter consumes 1000W from the 12V battery, then a 90% effecient converter would generate 900W of 120V AC power best case. The other 100W is lost primarily as heat.
The other thing that gets tricky is that these ratings and the formula above are used for resistive loads, like light bulbs or hair dryers. Anything with a motor or transformer is considered an inductive load and can get much more tricky to calculate.
Consequently you need to give your self a safety margin when figuring out how big an inverter you need.
How does work in a practical sense?
Lets say you want an inverter for TV, DVD and Sat. Receiver. Look at the back of TV or in the manual. It should say how many watts it consumes. Lets say it is 400W. The DVD might be 100W and the Sat. receiver 50W - just as an example.
400 + 100 + 50 = 550 Watts. (just as an example)
You might think, well no problem, I'll use a 600 Watt inverter and have 50 watts left over. Depending on your inverter, that 600W might really be 600 x 90% effecient = 540 Watts of AC, less a 20% margin of error for the inductive transformers in the electronic of the TV, DVD and Sat. receiver 540 - 20% = 432 Watts.
Now you can see your 600 Watt inverter isn't big enough to do the job.
If we really need 550 watts of AC, add 10% to make up the effiency loss, then add a safety margin for inductive loads.
550 + 10% = 605 + 20% = 726 Watts.
Sounds more like an 800W inverter fits the job.
What does that mean in terms of wiring the 12V batteries to the inverter?
from the formula above:
In our example, we have an 800W inverter that runs on 12V
The current would thererfore be:
current = 800 watts divided by 12V
current = 66 amps.
That is important info because you can not use light gauge wire to carry 66 amps worth of 12V to the inverter nor could you use a 20A fuse to protect your inverter.
Now that's a lot of science for a guy who just wants to run a toaster on an inverter right?
800W / 120V = 6.66 amps
Using garryp's ratio 11:1, 6.66 x 11 = 73 amps.
That is a good ratio with a good safety margin.
This is all just MHO and should not taken as solid technical advise. In other words, don't blame me if you blow yourself up.
Nov 26, 2008 | Coleman 5640B807 Compact Refrigerator
Looking for replacement parts for vector spot light
The bulb you are looking for to fit these vector spot lights is an automotive bulb, and H3 with a PK22s base. They come with a cable and a nickle size disk at the base of the bulb. They come in several wattages, eg 55w and 100w. Try the "bulbs.com" website, in their search box type "H3 PK22s" and you will see they have a variety of wattages and voltages. Be sure you buy a 12V for these spot lights. They come with a cable and nickle size disk at the base of the bulb. Hope this helps. From Uncle Ray
Oct 06, 2008 | Camping, Backpacking & Hiking
Science & Laboratory Logo
148 people viewed this question
Top Zeiss Science & Laboratory Experts
Gep Pep
 Brian Main
Brian Main
Terry
Terry
Are you a Zeiss Science and Laboratory Expert? Answer questions, earn points and help others
