Question about Lexmark X5650 All-in-One InkJet Printer
Printing I try to print multiple pages from one email and I know there are 20 pages and it only prints one and the others aren't.
Posted by Micael Myers on
Big Steve
  • Lexmark Master
  • 1,087 Answers
Normally if you say 'Print this email' it prints all the pages automatically. Try going on to the Advanced printer section and where it says print pages from... to... give page numbers
Posted on Apr 11, 2014
5 Related Answers
Anonymous
SOURCE: my printer only prints the first page
You may want to verify that your in your printer menu it is set up to print the entire document not just the screen view document. If it is on the screen view it will only print what you can currently see, not the additional pages.
Posted on Aug 24, 2007
Riztech
Mohammed Rizwan
  • 731 Answers
SOURCE: Having trouble printing a document file in word
Steps to troubleshoot:
1.Look in print preview (file-print preview)
Check that u could see all the 4 pages in print preview with same alignment.
2.Still if u cant print, then there is problem with the format of ur document..Save the file with .doc extension
3.Still the problem, Uninstall the USB composite Device of the printer from the devicemanager(Right clk my computer-properties-hardware - Device manager-Universal serial bus controllers).then reboot.
Posted on Feb 09, 2008
Anonymous
  • 65 Answers
SOURCE: only prints last page or least few pages of a ulti page document
if your taskbar displays printer icon on system tray double click on that & delete all privious prints.
select the text or area which you want to print. & give print command, & Click on print selection button & then Print.
Posted on Feb 23, 2008
Sanath Kumar V
  • 684 Answers
SOURCE: lexmark x4650 AIO, will only print first page of multiple pg doc
In this case what i would Request u to do is......... Goto Control Panel goto Printers folder......... There u will see the Lexmark Printer Icon........... Just right click on the Printer Icon and click on Properties......... Now click on Advanced and goto Print Processor......... Change it to Lexmark X1100 and NTEMF 1.0008........ Click on Apply click Ok now try to Print.......... Prints Fine............Issue Resolved........
Posted on Feb 05, 2009
Rachelkraj
  • 14 Answers
SOURCE: printer only prints one page of multiple page document
hi..
You may try to change the spool data format:
1. Click on "Start," "Control Panel," "Printers and Other Hardware" and "Printers and Faxes."
("Start," "Control Panel," "Hardware and Sound" and "Printers" for Vista...)
2. Then, right click on the Lexmark printer icon and left click "Properties."
3. Either on the "Advanced" tab or the "General" tab for some models, there is a "Print Processor" button, left click it.
4. This is the spool format setting. Under "Print processor" it should be set to "Lexmark *** series print processor." Next, under "Default datatype," select "NT EMF 1.008."
5. Click "OK" and exit back out to your desktop.
6. Try printing again.
Posted on Apr 24, 2009
How do I print multiple booklets?
It may be specific to your OKI printer driver. Refer to it's manual.
Apr 24, 2015 | OKI Office Equipment & Supplies
We have printing of pdf files in multiple,nere by 1 lakh pages within 2-3 days but now printer is printing 250-300 pages in one hour. how to increase the speed of printing ? email id ---...
Change the printer's print settings to print in draft mode.
Draft mode is a low quality, but highest speed print mode.
  1. In Windows, click on the Start button and choose Control Panel.
  2. Choose Printers and Other Hardware from the menu that opens.
  3. Choose View Installed Printers or Fax Printers.
  4. On the window that opens, look for your printer's name. Right click on the printer's icon and choose Printing Preferences.
  5. On the Print Quality tab, choose Draft or Fast (varies depending on the printer).
Mar 05, 2011 | Office Equipment & Supplies
Single page email prints multiple pages
Firstly in one PC reload the OS and other necessary softwares and try printing an email. If u get the same results, then check the printing options both on the printer side and the outlook print properties. Hopefully this wont be needed because when you reinstall the OS as a clean install it should print properly....sodeep
Apr 14, 2009 | Microsoft Windows XP Professional for PC
New printer won't print multiple pages.just 1 of 1
Change the driver setting, in the driver there is language the machine use it in order to communicate with the pc. check if you are using GDI or PCL or other driver language, change this setting to PCL or try to switch to other ones, and make printing test.
you can do this from the machine too.
if none of those works uninstall then install back trhe real driver.
Good luck
I’m happy to help further over the phone at https://www.6ya.com/expert/mustafa_06f84c65ab5cc745
Mar 12, 2009 | Office Equipment & Supplies
Printing large sheet on small pages and piecing together.
is your building plan is an image ? if the answer is yes,
you can save the image, than you can print it from excel.
hope this help...
Mar 10, 2009 | HP Office Equipment & Supplies
Printer only prints one page of multiple page document
i dont know how to conect lexmark printer X4250 to my computer
Dec 25, 2008 | Lexmark X4270 All-In-One InkJet Printer
Printer will only print page 1 of multiple page documents
1. Check that you are using the latest print driver - from kyocera website.
2. If the issue is when you print pdf files then make sure you set the printer in KPDL Auto mode - check the print driver settings about this and the printer menu.
3.You may check if you have the latest firmware installed within the printer - print a service status page (Menu->Others->Service).
Nov 26, 2008 | Kyocera FS-C5030N Led Printer
Multiple page printing
if it's one original making 20 copies and doing the problem then you have a problem with the
a) Primary
b) Seperation unit
I would change the Sep 1st
Sep 08, 2008 | Canon PC-940 Black and White Copier
Lexmark X5650 All-in-One InkJet Printer Logo
Top Lexmark Office Equipment & Supplies Experts
Muntejaya Ginting
Muntejaya Ginting
CheckitRight
CheckitRight
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
