I also cleaned the filter,checked the impeller and water does come out of the water line to the dishwasher. Now what do I do?
There is a possibility the water pressure itself is low from the kitchen line or the dishwasher is set at incorrect water pressure setting and does not collect enough water based on the flow time of inlet valve. If you hear the wash motor cut in then there is not enough water in the base to start pumping it to through the arms.
SOURCE: LG Dishwasher LDS5811ST 1E error code
I had a LG certified repairman come out and fix. The electrical wires within the door were melted into the "tar" (sound deafening spray) and one wire actualy sheered. Apparently the drying cycle heats the tar and the wires become embeded and melt into the tar. This is what was causing the error code. After the wire was tested and spliced everything worked great. Long term...The door/electrical harness was replaced by LG.
SOURCE: E1 error on LG dishwasher
As per my email reply chazmano5, the problem is likely to be the water pump/motor assy.
They have a very common fault of the impeller breaking on the motor shaft. The motor still spins, but the impeller doesn't, so there is no water being pumped.
The machine senses there is no water pressure and shuts down, displaying E1 (eg: it thinks no water pressure means there must be a water leak) Unfortunately the motor/impeller is only available as a complete assembly.
Just to review, the LG dishwasher family, including the LDS5811 has the Verio motor and the check valve that diverts water from the bottom rack to the top rack.
If the valve is blocked/jammed, this would cause the symptom you describe. The valve is visible from inside the DW after you open it up.
It is also possible that this motor has failed.
SOURCE: LG LDS5811WW Low pressure out of spray arms
On the LG LDF xxxx dishwasher family, the Vario feature uses a motor/check valve to switch between "full power" cleaning from _either_ the lower or the upper spray arms, never at the same time. So, not seeing the upper arm spin during the lower arm spinning is standard operating procedure.
But back to your problem. Step one would be to remove the filter assembly again and make certain that there is nothing (debris, broken glass) blocking the white areas where the check valve rotates to switch between upper/lower spray arms. A blockage there ~could~ cause impotent spraying/cleaning.
If there is no blockage and the impeller remains in good shape, suspect a failing wash pump motor. Try to isolate the noise to that motor.
Watch for error codes on the display and report back what you find, OK?
Good Luck!
SOURCE: Top arm in dishwasher will NOT spin!
When you say the top arm does not spin, remember that the LG model x811 family has the Vario feature that alternates between routing the pumped water to the bottom arm and then the top arms alternately. So anytime the dishwasher is washing and rinsing, either the lower or upper arms will be spinning.
If the problem is not above, then the motor that drives the check valve may have failed (or the check valve is obstructed inside.)
Hope that helps. Please post back here with what you find, OK?
