Question about Vtech 5.8GHz Analog Cordless Phone
I'm unreachable when people call me it always shows my phoe busy, i'm sure its something i.ve done, but i don.t know what
Posted by bobios on
  • lubalibra79 Mar 27, 2009
    when i try to make a the line will be busy. when trying to call the number i don't hear a ring.
Anonymous
  • 65 Answers
I WOULD TAKE A CORDED PHONE OUTSIDE TO THE NETWORK INTERFACE. YOU WILL NEED A SCREW DRIVE TO OPEN THE BOX. THERE IS A SCREW TO LOOSEN AND WHEN IT TURNS FREELY THERE IS A LATCH ABOVE THE SCREW OPEN THE BOX THERE SHOULD BE A PLACE TO UNPLUG THE WIRING FROM THE TELEPHONE COMPANY'S LINE. PLUG YOUR PHONE INTO THE PLACE YOU UNPLUGGED FROM. IF YOU HAVE CLEAR DIALTONE THERE YOU HAVE A PROBLEM INSIDE. YOU CAN CALL YOUR NUMBER FROM A CELL PHONE TO SEE IF YOUR PHONE RINGS.IF YOU DO NOT GET A DIAL TONE AND IF YOU CAN NOT BE CALLED IT IS THE PHONE COMPANY'S PROBLEM.
Posted on Jan 26, 2008
Anonymous
  • 52 Answers
Hi your call divert might be active on your phone menu so i would go it and deactivate it!
Posted on Nov 02, 2007
HOW DO I TRANSFER MY CALLS TO ANOTHER PHONE?
1. Find "Voice call"
2. Select divert type
3. Divert calls to alternative number
  • Key in the required number and tap Enable.
Aug 28, 2014 | Samsung Galaxy S Iii Gt-i9300 - 16gb -...
NAS unreachable
That means the NAS has an IP outside of your network range and your router doesn't know how to route traffic to it. Say your home network is 192.168.0.0 This is the network address. Your subnet mask is 255.255.255.0. This means the first three groups of numbers are your network so your network is 192.168.0.X the X can be any address from 1-254. The X is also considered the host. Now say the NAS has been set to an IP, maybe as default, to 192.168.1.2. See the 1 in there 192.168.1.0 is a different network than 192.168.0.0. Your router doesn't know how to route to this network. Therefore the destination is unreachable. This is one cause of this error.
Jan 11, 2013 | Computers & Internet
SH125 speedo & fuel gauge dead
To start with when asking for help, ALWAYS STATE your make and model. No matter what product you are talking about.
Dec 06, 2017 | Honda SH 125i Motorcycles
Hi I've got a 2011 ktm 350sxf but it won't start
Without knowing the bike, I can only give you somethings to try. Pull in the clutch, make sure the sidestand is up and that the ignition is switched on ( you may have to apply the front brake as well, as they have always been very safety minded ) Then press the start button, Don't forget to make sure it is in neutral as well. Good luck.
Mar 31, 2012 | KTM 250 SX-F Motorcycles
Unable to connect to cable network after downloading network drivers
You need to be sure that your network settings are properly set. If you're behind a router, make sure that your computer is in the same network with it. Ping any website like google.com and see the result by entering this command in command prompt: ping google.com. Here is a picture showing what you should see if everything is ok.
If your result is something like "Destination host unreachable" or "request timed out" try this command: ping 173.194.66.103.If you have ping with the second command - you should fix your DNS input in Network settings. Usually for DNS server you should use the IP address of your router.If you have ping in both scenarios - you should check Internet Options of your Browser. Make sure you have entered proxy settings if you're using one. Make this initial diagnostic and write about the results so that I could help you.
Dec 07, 2011 | Gateway 505GR PC Desktop
I've rebuilt several briggs and stratton pushmower
I have not removed an oil slinger yet, but these guys have done many. I am a member of their site you enjoy their comments.
http://forums2.gardenweb.com/forums/load/tractor/msg102128206869.html
Jun 24, 2011 | Briggs & Stratton Garden
Cannot copy two side.paper always jam
Are you sure there is not something blocking the paper going inot the duplexer. I've had one of the fuser separation claws fall off and block the path. Now if that is not the case then check to make sure some of the sensor arms don't have paper cuts in them. This will cause an intermittent delay jam. Jam codes in service mode will also help.
Jun 17, 2011 | Canon NP 6050 Copier
Took 2009 fusion sel for 4 new tires at local goodyear, when returned the front end shakes, take back still shakes, take back third time and the front doesnt shake, but the turn indicators don't work,...
sounds like you had the "new kid" working on your car. its hard to find good help these days. the service adviser should have had his better technicians look at it after the first numb skull laid hands on it. as far as the lighting problems i would say it sounds like a blown fuse or an unplugged light connector. you should have your ford dealer check it out and see if it looks like something has been tampered with. good luck. and try firestone complete autocare next time. usually better managed. usually.
Jun 10, 2011 | 2007 Ford Fusion I4 SEL Sedan
2003 Harley Road King....Just had the rear tire replaced and now I hear a slight whining noise. Pulled off the interstate for fuel and almost every gear "Jumps" unless I really baby the throttle....
Hmm! This is a difficult one as I can't feel the tension of the belt nor hear the sound for myself. Any time you have anything done to your machine by anyone, ALWAYS CHECK BEHIND THEM. Mechanics are only human and as such, we make mistakes just like everyone else. There is nothing different in a Harley-Davidson mechanic than any other mechanic. And, since it's you riding the bike, you have a vested interest in making sure that your bike has been repaired correctly and is safe to ride. Always go behind the mechanics and check for loose bolts and things that are not done correctly within the scope of your knowledge of your machine. If you don't know anything about your bike, at least look for obvious things that were overlooked. It's for your own safety.
As for the noise. Check the alignment of the rear wheel in the swingarm. Make sure the inside edge of the final drive belt is not rubbing the edge of the tire. Check the tension of the drive belt. Most drive belts feet "too tight" to the average person in that they don't feel like they've got any slack at all when you check them. It should have something like a 1/2" deviation with a 10 pound force applied to the belt. Usually, a loose belt will "chirp" when you change gears. Sight along the top of belt looking toward the engine and see if it looks straight. Check the adjuster screws to see if they're the same length. Basically, look for obvious things wrong. If you're still in doubt, take it to a shop and have them look at it. On several occasions, I've seen people load their bikes too heavily and the bike sits down in the rear end. This caused the top of the final drive belt to rub the underside of the inner primary just below the starter and make a whining noise. All I did was to tighten up the shocks just a bit to stop the problem. You may not can see this as you must be sitting on the bike to check. Get a friend about your same size to sit on the bike or someone else to check it while you sit on the bike.
This is about all the advice that I can give you without actually putting my hands on the bike which I can't do. I wished I could have helped more. Always remember, it's your fanny riding that bike and if something isn't done correctly, it's your fanny that may get skinned up. You don't have to be a high-dollar mechanic to notice things that just don't look right on your bike but if you don't look, you won't see them. NEVER trust any mechanic to not make a mistake. I've been doing this for years and I still make mistakes from time to time but usually I catch them before the owner gets the machine back. See, I learned to check behind myself years ago.
Ride Safe
Steve
May 03, 2011 | 2003 Harley Davidson FLHRCI Road King...
The gas gauge is not registering when gas is put in the van
I don`t know this particular car but I don`t think the dissy has anything to do with the fuel gauge. Did the fuel gauge work perfectly before?? If so, you`ll probably find that you`ve disturbed a connector which goes to the sender unit. It`s very easy to do, I`ve done it myself and it`s VERY annoying to find you`ve sorted one fault only to find that you`ve caused another fault. Just go over everything that you`ve touched and done to the car. Did you short something out when you were replacing the cap, if so, you`ll probably find that a fuse has failed and it`s not just the gauge that doesn`t work. All the best, Ian
Aug 05, 2009 | 1998 Nissan Pathfinder
Vtech 5.8GHz Analog Cordless Phone Logo
116 people viewed this question
Top Vtech Lands Phones Experts
Marvin
Marvin
Ekse
Are you a Vtech Lands Phone Expert? Answer questions, earn points and help others
