Question about Brother MFC-9420CN All-In-One Laser Printer
Can't Scan in Imac, via adobe acrobat. Not able to pick printer from the use this scanner field
I have been scanning in to acrobat writer in windows PC from the same brother printer MFC-9420CN. But when I tried to scan in to Apple Imac I am not able to see the scanner in the drop down list. I am able to print to the printer from the Imac. I think there has to be some kind of scanner setting in Apple but in preferences there is only printer no scanner option.
Posted by ninad23 on
  • Anonymous Nov 29, 2007
    previously all the 8 pc'sconnected on the network were able to use the scanner but now only one pc is able to use the scanning service and the rest are unable to access the scanner but they are able to use fax and photo copying.
  • twilkin Jan 16, 2009
    Same problem. Scanner doesn't show up in drop-down menu in Adobe Acrobat.
    I'm using a Mac Pro, OS X 10.5
Anonymous
Buy a PC!
Posted on Nov 13, 2007
Brother mfc-9420cn unabel to scan
I work at Office Depot. Bring it to one of our stores and we can look into it and diagnose it. Usually it is as simple as a loose toner cartridge.
Dec 14, 2011 | Brother MFC-9420CN All-In-One Laser...
My Brother MFC-7840W scans into TIF files as individual pages. At my former job, we scanned directly into multi-page PDFs. What am I doing wrong?
You need to install a PDF writer program first. There arequite a few freeware PDF writer programs on the Internet you can download onesuch as CutePDF.
Scan your document the click on File - Print and select the PDF writer as theprinter device. Then name and save the PDF file. http://www.cutepdf.com/
Feb 21, 2011 | Brother MFC 7840W Printer
Brother MFC 6800 won't send scan results to iMac. The scan function appears to work, although nothing appears when using iPhoto or Picass for Mac. I am using Mac OX 10.6.5
Hi
I had the same problem. I knew the scan function was not broken because I could use it with my old PowerMacG4. But no go with the new Intel iMac, and no amount of driver updating or other OS fiddling solved anything.
I luckily found another MFC-6800 to test. And to my surprise scanning is working, and printing is much improved (no more "offline printer" when it's clearly online). The difference between the two: firmware version. My MFC is dated from 2001, while the other one is from 2004. For the date see the label behind the machine.
Now, why does scanning work on my old PowerMac G4? Apple probably changed something in the Intel drivers or the USB circuitry, or Brother didn't adhere to proper standards in 2001. Or it may be as stupid as an inability of the older Brother board/firmware to deal with USB 2 levels, even throttled down to USB 1.1. Who knows? Anyway I'm in contact with Brother and hope to get a way to upgrade the firmware in my printer.
Did you try scanning with Graphic Converter? Some Adobe products need updates to properly scan in Snow Leopard.
Hope this help.
Dec 13, 2010 | Brother MFC 6800 All-In-One Laser Printer
I need to scan and it just keeps saying" Conecting to PC"
It is looking for the scan software on your computer, it won't scan unless the scan software is running so it knows where to send the image. The scanner will still work for copying, but it only scans to the computer if you choose scan on the front panel.
Aug 27, 2009 | Brother MFC-9420CN All-In-One Laser...
Mfc-9420cn scan button does not initiate a scan
You should switch to scanning mode on the printer's interface!
Jul 15, 2009 | Brother MFC-9420CN Laser Printer
How do I scan a document with a MFC7420 & make it e-mailable?
I called Brother technical support and they walked me through the configuration and device settings. Can do it fine now.
Thanks, Carole
Jan 29, 2009 | Brother MFC 7420 All-In-One Laser Printer
Scan from brother MFC 8440 to pc
you need to make sure that the brother printer is et as the default printer
Dec 19, 2008 | Brother MFC-8440 All-In-One Laser Printer
Only Scans one time a day
What is your OS and what porgram are you using to scan in and what is your connection type?
May 14, 2008 | Brother MFC-9420CN All-In-One Laser...
Brother MFC-9420CN All-In-One Laser Printer Logo
349 people viewed this question
CheckitRight
CheckitRight
James Cagle
James Cagle
Jim Keysor
