Camera is off but lens is extended. when pressing the on/off button: lens retracts, screen flashes once and lens comes back out and screen remains dead. No other buttons have any effect.
SOURCE: lens retract problem
The following blog outlines some repair options for a lens error. They won't work for all cases, but they're worth a try if the camera's no longer under warranty:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
SOURCE: A460 lens error, restart camera
SOURCE: Lens problems... kind of
HEY, I REALLY LIKED YOUR PRESENTATION OF YOUR PROBLEM! VERY WELL DONE! I'M GOING TO OFFER A SOLUTION THAT I THINK WILL SOLVE YOUR PROBLEM. I THINK YOU NEED TO GO ONLINE TO TO THE CANON WEBSITE AND DOWNLOAD THE LATEST FIRMWARE FOR THE SD750 OR AT LEAST DOWNLOAD A FRESH VERSION, THEN CONNECT YOUR CAMERA TO THE COMPUTER AND SYNCRO THE TWO AND SEE IF THIS DOESN'T SOLVE THE PROBLEM. I BELIEVE THAT WHAT HAS HAPPENED IS THAT THE FIRMWARE HAS BEEN CORRUPTED SOMEHOW AND YOUR CAMERA IS GETTING CONFUSED SIGNALS. RESETTING IT TO FACTORY DEFAULT FIRMWARE SHOULD SOLVE THIS PROBLEM. IF IT DOESN'T THEN I THINK THERE IS A POSSIBILITY OF A MECHANICAL PROBLEM, BUT RIGHT NOW I FEEL IT IS A FIRMWARE PROBLEM. TRY THIS AND SEE IF THIS DOESN'T WORK.OK? REPLY TO:ARCLIGHT1217--GOOD LUCK!
SOURCE: Lens error, restart camera
Lens error is usually caused by mechanical faults concerning lens assembly. The lens cannot extend or retract fully, the error is detected and lens error is returned.
Sometimes this can be fixed playing with the lens during extraction or retraction to help the lens asset getting back to normal.
More often the camera lens must be disassembled and re-assembled by a technician to fix the problem.
SOURCE: lens error, restart camera. canon
Fixing a Lens Error on a Digital Camera This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include "E18 lens error", or "lens error, restart camera". Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move. The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous interiors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many cameras, and NEVER use a case for this very reason. A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth. Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods. The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired: Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on. Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time. Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particles that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera. Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots. Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in "no heat" setting, or sucking the gaps with a vacuum (careful with this one). Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes. Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens. Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
I'm sure that every1 looking at this right now would love to
be able to do a quick fix for the dreaded E18 error. Well, I have fixed mine
several time in less time that it takes to take a picture. So here it is: This
error occurs when the lens is "stuck" or not extending "straight". The error can
happen in 3 ways: either when the lens wont "come out", or "comes out" and then
retracts, or does not retract at all. Mine did all of these at one stage or
another.
1) If the lens doesn't extend at all or it extends, but then
retracts again, do as follow:
Turn the camera off. Place the camera on it's
back with the lens facing up and have a look at the "spacing" between the lens
and the lens housing. You'll probably notice that the gap is NOT EVEN all the
way around. To fix this, simply -VERY GENTLY- press down on the side where the
gap is the biggest. You will hear a "click" as it pops back in place. Try
powering it back on.
2) If the lens is extended all the time and won't retract at all, do as follow:
Turn the camera off. Take the camera in one
hand and with the other gently, in turn, take the two part of the lens and
gently move it round in a circular movement. Do so with both sections of the
lens. You will once again hear a little "click" as it pops back in place. Power
the camera on.
This has worked for me many times and it seems to happen when
the camera has been carried around and possible had a little knock. I hope this
is of help to someone else.
