Safety First: Before attempting any repairs, ensure the steamer is unplugged from the electrical outlet to prevent electric shock.
Access the Switch Relay Area:
Remove the water tank from the steamer.
Open the casing or access panel where the switch relay is located. This may involve removing screws or clips.
Inspect the Wires:
Look for any loose or disconnected wires near the switch relay.
If you find a wire that has come off, identify its original position.
Reconnect the Wire:
Strip a small portion of the wire insulation if needed.
Reattach the wire to the appropriate terminal on the switch relay.
Ensure it is securely fastened.
Test the Steamer:
Reassemble the casing or access panel.
Plug in the steamer and turn it on.
Check if the switch relay works properly.
Secure the Casing:
Once everything is in place, secure the casing back onto the steamer.
Remember to exercise caution while handling electrical components. If you're unsure or uncomfortable with the repair, consider seeking professional assistance or contacting Conair's customer service for guidance.
CONAIR GS4 SERIES INSTRUCTIONS FOR USE Pdf Download ' ManualsLib
