Acer Extensa 5620 running Vista Starter, cannot perform windows updates, it states it is downloading and installing updates, but in the end, it fails and the error message indicates the "windows installer cannot be accessed". The system will also not allow uninstalls of software previously installed.
SOURCE: How do I install windows vista on acer 4920
hi,
here is one helpfull link but remember backup your important data from your system before going in for reinstall
http://vistahomepremium.windowsreinstall.com/upgrade/upgradetovista.htm
if this method doesn't work let me know
Further queries are welcome
SOURCE: dvd drive won't work
The drive is probably defective. You can try to reseat the drive. Usually they're held in with one screw on the bottom of the laptop. Once you remove the screw you can just pull the drive out like a drawer and then stick it back in. If it doesn't work then it's likely that it's defective. You can get a replacement on ebay by model number or using the part numbers that are on the drive itself.
Hope this helps!
SOURCE: acer extensa 5620
i have laptop acer extensa 5620z, install windows xp professional os 32 bit, inside device manager open that time
Ethernet controller
Ethernet controller
Mass storage controller
Pci device
Pci device
SM Bus controller
Universal serial Bus (USB) controller
biling the yellow(!) mark, and usb device put in the usb port not open how to solve this problem, please reply me, thankyou,
my email [email protected]
SOURCE: windows vista starter update and install failed....
Make sure all programs are closed and run updates. It will take a while with that many updates. You may have to run it more then once since some of the updates won't work till the previous ones are installed. One way to do it to take less time start with the oldest and only install a few at a time. They do not have to be all installed at once. That way you can install a few each day till you have them installed. Also look at the updates some may not be needed if you don't have or use the programs the update is for. Also internet explorer 8 is not needed with vista and it does cause problems in the computer if installed. That is why you should look at and only install what is needed.
SOURCE: media touch acer
Hello
Make sure you download this
Acer Launch Manager
Please uninstall the current driver for synaptic and install this
Windows 7 Synaptics TP Driver 10
Hope it helps ;)
