Fridge drips condensation from where compressor pipe goes into fridge!
SOURCE: fridge constantly dripping wet
water inside, too much condensation from humid air entering fridge from bad seals. replace the seals. could also be that the condensate drain is clogged. if it's leaking from the bottom of the fridge, make sure the tubing is still inside the condensate pan underneath the fridge.
SOURCE: hello!ad my black glass fridge freezer delivered
Post your model number for filter help. The water supply hook to the water inlet valve on the back, Usually near the bottom. It has a fitting where the incoming water will fit. You may have to remove part of the cardboard on the back to get to it.
SOURCE: Freezer is not cold and evaporator fan (inside
ok well... those pipes coming from your compressor one of them should be hot. if not your compressor is not running.
Testimonial: "Thank you for the response Fridgie!"
SOURCE: Hotpoint Iced Diamond fridge freezer, fridge seems
In case the freezer not getting cold. maybe the tube is leaking .the freon gas scape. or your compessor is defective
SOURCE: Water gathering in pipe in
Hi you will find this is a common problem bits of food get into this outlet and it gets blocked you should have got a small tool with the freezer when you bought it if not use a small screwdriver or smilar item to unblock the hole and you will find this will solve the problem
