A
Anonymous Posted on Apr 11, 2014
Apple iphone usb driver - Hyundai Audio Players & Recorders
Ted Robey
Level 1:
New Friend:
Welcome Back:
Visited the website for 2 consecutive days.
  • Contributor 4 Answers
  • Posted on Mar 03, 2015
Ted Robey
Contributor
Level 1:
New Friend:
Welcome Back:
Answers
Questions
0
Helped
1057
Points
9
Take the sonata to your dealer for a firmware update of the radio system, it is a free service
When i plug my iphone 4s into my pc with itunes running it doesnt recognize the phone, cable is good pc makes sound when i plug in
There are several methods you can try to fix this issue. One of them shows below.
How to Fix iTunes Not Recognizing iPhone in Windows 10 Before You Begin:
  • Make sure that you have the button Trust this computer on your iPhone when connecting to your PC.
  • Make sure that you have installed all Windows updates. This is to make sure that your computer device drivers are up to date.
  • Make sure your iPhone USB cable works well.
  • Make sure your iOS device is turned on.
  • Make sure you have the latest version of iTunes installed.
  • Now, the following solution may help you fix the iTunes issue if you found that your iTunes does not recognize iPhone in Windows 10 computer.
    Step 1. Connect your iPhone to computer and wait for some time until the device is recognised.
    Step 2. Right-click "Computer", Go to "Device Manager". Then expand category "Universal Serial Bus controllers" and locate "Apple Mobile Device USB Driver".
    Step 3. Right-click "Apple Mobile Device USB Driver" and click "Update Driver Software". On the pop-out window, choose "Browse my computer for driver software".
    Step 4. Then choose "Let me pick from a list of device drivers on my computer".
    Step 5. Click "Have Disk..." button.
    Step 6. Click "Browse".
    Step 7. Navigate to "C:\Program Files\Common Files\Apple\Mobile Device Support\Drivers". Then double-click the usbaapl file. If you have a 64-bit version of Windows, this file will be called usbaapl64.
    If you don't see usbaapl64 here or if there isn't a Drivers folder, look in "C:\Program Files (x86)\Common Files\Apple\Mobile Device Support\Drivers".
    Then you need to install the driver for your Windows 10. After installing, unplug your iPhone, then reconnect it using USB cable. Open your iTunes and see if your iPhone can be detected or recognized by iTunes.
    For more details, check: How to Fix iTunes Not Recognizing iPhone in Windows 10
    Connect internet usb modem driver china install
    connect the usb to ur laptop and the other end to the iphone and download the driver of the phone. you should be fine.
    1helpful
    Instruction manuals for to put sim card
    The Apple iPhone 4S manual or user guide has been published by Apple at their website. This Apple iPhone 4S manual is available online and you can download it directly from apple.com. The Apple iPhone 4S user guide is written in 163-pages of PDF document format (15.39 MB). You can download this manual directly to your Apple iPhone 4S smartphone and read it by using PDF reader application. This Apple iPhone 4S user guide provides complete information and instructions about how to operate the Apple iPhone 4S mobile phone properly. Don't forget to check these supplied accessories before operating the Apple iPhone 4S smartphone: iPhone 4S, Dock Connector to USB Cable, Apple Earphones with Remote and Mic, USB Power Adapter, and Documentation.
    2answers
    Should my iphone 4 turn on when connected to USB
    yes your iphone will turn on when its getting connected to the USB..
    than only it can synchronize with you mobile..
    thank you for using fixya have a nice day:-)
    4answers
    ITUNES DOES NOT SEE MY IPHONE
    the same exact thing happen to me......then I purchased a new connector (I used the old usb so much with the ipod)...and bingo itunes recognized the iphone......
    IPhone Smartphone: iphone won't sync with laptop...
    1. try another USB port.
    2. try restarting iPhone and laptop while both are tethered together.
    3. Update USB drivers on your laptop.
    4. try reinstalling iTunes.
    5. Try restoring your iPhone.
    IPhone not recognized by pc, in recovery mode
    Method 1. Manually Update the Apple Mobile Device USB Driver
    Step 4. Choose "Let me pick from a list of device drivers on my computer" and click "Next".
    Step 5. On "Update Driver Software - Apple Mobile Device USB Driver" box, click "Have disk". However, if this button is not available on this box; click a device category like "Mobile Phone" or "Storage Device" in case if that is what you see.
    Step 7. Navigate to "C:\Program Files\Common Files\Apple\Mobile Device Support\Drivers". Then double-click the usbaapl file. If you have a 64-bit version of Windows, this file will be called usbaapl64. If you don't see usbaapl64 here or if there isn't a Drivers folder, look in "C:\Program Files (x86)\Common Files\Apple\Mobile Device Support\Drivers".
    Step 8. On the "Install Disk" window, click "OK".
    Step 9. Click "Next" and after this, Windows will assist you with the driver update.
    Now, you are ready to go. Open iTunes to check if it recognizes your iPhone
    If this method won't work, check this guide for more methods. How to Fix iPhone Not Recognized by Windows
    IPhone to PC not working
    check the usb cable. (try different cable if there's any)
    OR
    try to connect the cable to different usb ports.
    OR
    try re-installing software/drivers.
    1helpful
    How to transfer a game which is downloaded by www.apple.com from computer to an apple iphone 3g.. can it will happen through itunes software??? if yes how?
    First of all you need to install the USB or data connectivity cable for your apple iphone 3g on your computer.
    You can get the installation and driver software on the CD that came with your apple iphone 3g phone.
    Also install the PC Suite of your apple iphone 3g on your computer as well.
    Connect your phone to your computer through your USB cable or whatever connectivity means you have. Transfer the game file to your apple iphone through the PC Suite application.
    The PC Suite applications enables a proper transfer to the right game folder on your phone
    1helpful
    IPhone can't charge and can't be detected by PC
    Be sure that your Windows PC meets the minimum system requirements to use iTunes and iPhone. This is particularly important if you are connecting iPhone to your computer for the first time. iPhone requires a specific minimum version of iTunes.
    Ensure the computer's drivers are up to date
    iPhone requires USB 2.0 to function properly. Refer to the documentation for your computer to verify that the USB ports are high-power USB 2.0 ports. Try connecting iPhone to a different USB port, preferably a port that is built-in to the computer instead of an external USB hub. Connecting iPhone to your keyboard's USB ports is not recommended.
    In some cases, your computer's USB ports may become temporarily disabled or you may experience other software related issues. Restarting your PC is an easy troubleshooting step that may resolve this issue.
    iPhone requires two important pieces of software to operate properly on Windows. First, the driver must be installed; for iPhone the driver is USBAAPL.SYS. Second, Apple Mobile Device Support must be installed as a Windows Service. If these are not installed, see the Reinstall iTunes section below.
    Verify that the driver is installed by connecting iPhone to the computer and following these steps:
    1. On the Start menu, click Run.
    2. In the Open field, type devmgmt.msc and click OK. A list of devices will be displayed.
    3. Scroll down to Universal Serial Bus controllers and click the small plus sign to expand this group. iPhone will be listed as either Apple iPhone or Apple Mobile Device depending on the version of the driver installed.
    4. Right-click Apple iPhone (or Apple Mobile Device) and choose Properties from the shortcut menu.
    5. When the Properties window opens, select the Driver tab.
    6. Click Driver Details to view more information.
    Verify that the Apple Mobile Device Service is installed and running using the Services MMC snap-in using these steps:
    2. In the Open field, type services.msc and click OK. A list of devices will be displayed.
    3. View the list In alphabetical order and verify that the "Apple Mobile Device Service" status is "Started."
      1. If the status does not indicate the service is started, right-click Apple Mobile Device Service and choose Startfrom the shortcut menu.
      2. If the service is installed and started, right-click the service and choose Restart from the shortcut menu.
      3. If the driver is installed and the service is installed and started, check the Event Viewer for error messages.
        2. In the Open field, type eventvwr.msc and click OK.
    Jan 24, 2009 • Cell Phones
    Top Hyundai Audio Players & Recorders Experts
    SmartAviator
    SmartAviator
    ADMIN Andrew
    ADMIN Andrew
    Are you a Hyundai Audio Player and Recorder Expert? Answer questions, earn points and help others
