Question about Jet 3 Ultra Power Chair
PULL STRAIGHT UP WITH PERSON ON EACH SIDE.
PULL STRAIGHT UP WHILE MOVING BACK AND FORTH WITH PERSON ON EACH SIDE AND IT WILL COME OFF.
How to move the shift lever into neutral on a 2006 Kia Sedona when the battery is dead in the button will not move
If the car is parked on a grade/hill, with the transmission in gear will prevent shifting (pressure from the wheels through your axle/driveshaft). Have one person rock the car back and forth with another person (with strong fingers!) sitting in the drivers seat with the foot over the brake (if you're on a hill). As the person rocks the car slightly back and forth, see if you can disengage the safety button and move to N or P. Obviously engage emergency brake after that!
Dec 07, 2016 | 2006 Kia Sedona
SETTING TIMING ON 95 GMC SIERRA 2500
350, 305, 400. Crank shaft gear mark is straight up to the camshaft gear and the camshft gear is straight down to the crank shaft gear. If your looking for the rotor button / distributor. The button should be pointing to the number one cylinder (drivers side front) On the compression stroke. To find the compression stroke pull the number one plug , put you finger over the hole, crank the engine untill the pressure pushes your finger off, then put a stiff wire in the hole and turn the engine by hand (wrench) untill the wire comes up and just starts to drop. Move it back and forth to get top dead center. On the distributor Number one and number eight should be horizontal with the radiator.
Jul 02, 2011 | GMC Sierra 2500 Cars & Trucks
The van serems to stop straight but acts and pulls to one side bad,could swapping rotors do anything?
Not normaly, May need to get alignment. If alignment is ok you need to check your wheel bearings,, You can check this by jacking up front end and see if wheel had slack in moving back and forth. best of luck to you,
Apr 07, 2011 | 1999 Ford Windstar
Key got stuck in the on positionwould not turn off
Have a person help you--one guy move wheel back & forth--while other trys to pull out key-(don't twist key.)
Feb 17, 2011 | Pontiac Firebird Cars & Trucks
How to replace headlight bulb ?
when you open the hood and look down at the light fixtures you will notice a small steel clip on both sides of the lenses. Pull the clips straight up to release the lense body. Grab the lense on both sides and pull it straight out the front. You may need to wiggle it a bit back and forth, it has a habit of catching on the wheel well side of the vehicle. Once the lense body is out you can grab the wiring harness and turn it counter clockwise to release the bulb holder. Pull the bulb out and replace it and reverse the step to put it all back in.
Mar 13, 2010 | 2006 Chevrolet Trailblazer
I cannot get my sewing machine stitch the different stitches. I've followed all the instructions in the manual and all I get are straight stitches. I want to get a zig zag. Sometimes it looks like it did...
When you select a pattern does the needle move back and forth? do you make sure the stitch width lever is on straight stitch then select your pattern then select the widest stitch width? if when you select a zig zag stitch the needle does not move from side to side then you need to look in the top at the finger that goes round the cam.
Nov 04, 2009 | Singer 2732 Mechanical Sewing Machine
2000 Buick Century started pulling to the right on freeway.
if you hold the steering wheel straight ahead does the car move side to side or does the steering wheel fight you to move side to side.
Aug 24, 2009 | 1999 Buick Century
2003 GMC ENVOY DRIVER POWER SEAT WILL NOT MOVE FRONT OR BACK
if it sounds like it wants to but doesnt, like you can hear the motor but it is locked up, here is a way to fix it.look at seat and see if it looks sort of cocked and you may have to straighten the seat by keeping rod in one side or other and spinning it until seat is straight. there are 2 flexy cables that run side to side and cause the seat to move. they usually have a black plastic coating on them.remove them both. with both off hit switch and see if you hear the motors.If so you should lubricate tracks with silicone spray or spray grease.put cables back into holes and it should work.the cable may give you a lil trouble coming out but just pull back and forth they wont break
Jun 20, 2009 | 2003 GMC Envoy
Orbital or Straight Comparison
An orbital reciprocating saw moves in a more elliptical or oval shape rather than just up and down. This makes it more aggressive and gives it a faster cut. Straight reciprocating saws move on a single plane, back and forth.
Aug 27, 2008 | Makita Orbital Reciprocating Saw 2500 Spm,...
Jet 3 Ultra Power Chair Logo
74 people viewed this question
Top Jet Health & Beauty Experts
Marvin
Marvin
Vincent G
Vincent G
ray gallant
Are you a Jet Health and Beauty Expert? Answer questions, earn points and help others
