Question about Jensen VM9424 Car Video Player
Vm9424 no rear video
I can't get video at the rear monitor jacks. Tried everything.
How do you play a blue ray player through a Sony Dav DZ555K home theatre 5.1 system?
Run your hdmi to your tv and rca jacks to your sound system hope this helps Merry Christmas
Dec 03, 2017 | Audio Players & Recorders
I have a new vm9424 that was put into a 2005 h2. Main problem is i can reset the time, but once i drive it for more tha a mile the clock keeps resetting its slef to a /12 hour later than it is.. nor a...
CHECK THE CLOCK BUTTON SOUNDS LIKE ITS STUCK. IF ITS A TOUCH FACE SET THE TIME THEN MAKE SURE YOU GET OUT OF THAT PROGRAM AND GO SOME WHERE ELSE IN THE SYS. IF THAT DONT WORK SEND IT IN FOR WARRANTY REPAIR,
May 26, 2011 | Jensen VM9424 Car Video Player
Can the lens on a rca rear projection get dusty and cause blurry word and images?mostly words on my video games are unreadable ..xbox is hooked up via componite cables..running at 1080i..i have tried auto...
All ur convergence + - colors lines matches up wright?Yes.Than no,this problems are ur CRTS tubes colors guns R,G,B have bad CRTS coolant chemicals.Tries websites like Tvrepairworld.com,Tvrepairkits.com to buy a coolant kit to changes those CRTS coolant chemicals,should solved ur tv problem.
Nov 28, 2010 | RCA D52W20 52" Rear Projection HDTV-Ready...
Tv comes on and has no picture. menu there, video on monitor jack
This an old tv. From my experience i would replace it. It will be a money pit.Crts are beyond there life expectancey.
Nov 24, 2009 | Mitsubishi VS-50111 50" Rear Projection...
How to connect using a LCD monitor, cable box, DVD player
You won't need the VCR, that's only used for a cable box, and since you have one now there is no need. You'll want to connect everything with the better video plugin possible. Composite (red, white, yellow) is the worst, then s-video, then component (red, blue, green), then DVI, then HDMI. That will square your video. Then send all audio signals to the Denon. These cables are usually the red and white cables. OR Plug everything into the Denon to the appropriate input. Then connect the monitor to the video out of the Denon.
Jun 21, 2007 | Denon AVR-886 Receiver
Jensen VM9424 Car Video Player Logo
42 people viewed this question
Top Jensen Car Audio & Video Experts
Larry Tezekjian
Larry Tezekjian
Muntejaya Ginting
Muntejaya Ginting
Are you a Jensen Car Audio and Video Expert? Answer questions, earn points and help others
