Question about Sony Grand WEGA KF60XBR800 60" Rear Projection Television
Sony new lamp resetting procedures - Sony Grand WEGA KF60XBR800 60" Rear Projection Television
1 Related Answer
welcomejee
Shahid Electronics
  • 10594 Answers
SOURCE: comme on RESET LAMP Videoprojecteur
You can reset lamp timer of VPL-EX3 by following procedure.
Connect power cord in wall socket, standby indicator will lit red.
Press following keys on projector remote.. RESET, Left arrow, Right arrow, ENTER
Lamp timer will reset.
Hope this will help.
Thanks.
Posted on Mar 22, 2011
How can i fix my tv
Either lamp needs replacing or set needs reset. Try reset first; you can get reset procedure in owners manual. New lamp will cost $30 to $100 depending on where you purchase. Online search you can find out all you need to know about where to buy lamp and how to replace it. This model is easy lamp replace.
Aug 13, 2014 | Sony KDF-E50A12U 50" LCD HDTV
Lamp replacement
are you experienced in electronics first?
with out proper knowledge of electronics it is too risky to do it by yourself.
Jun 27, 2008 | Sony Grand WEGA KF42WE610 42" Rear...
Tip
How to reset the lamp timer on Sony Projection TVs.
If you have replaced the lamp in your Sony projection TV you must reset the lamp timer to get rid of the message saying that your lamp needs to be replaced. Let's face it, you know you already accomplished replacing the lamp but the TV isn't smart enough to know that. I will explain in detail how to accomplish the reset procedure.
Resetting the lamp timer is a complicated procedure but you should be able to do it if you have plenty of patience and know how to follow instructions. Read the procedure over first several times before trying to do it and locate all the buttons on the remote. You may want to try the procedure on the remote to make sure that you have the sequence memorized.
By the way the lamp life is figured to be from 5000 to 8000 hours. That is not much time if the TV is being used for more than 8 hours per day. If you do the math and watch your TV for 8 hours per day (not uncommon) the lamp will need replaced in 3 to 5 years. So be ready to do this procedure again in the very near future.
Here is the procedure.
All commands should be done using the factory remote:
1) enter the service mode by pressing display, 5, volume +, Power on
2) press JUMP 3 times
3) to display the time press channel 2, 9 times
4) to reset lamp timer press channel 3, MUTE, Enter
5) to check the time press channel 1, 7 times
6) when complete turn set off to exit.
Thanks for using FixYa and for the great rating. Please consider a testimonial. Thank You.
hardrocko
on Oct 30, 2010 | Televison & Video
Comme on RESET LAMP Videoprojecteur SONY VPL EX3 procedure ?
Thanks.
Mar 22, 2011 | Sony VPL-EX3 LCD Projector
Lamp reset by model number kvs50e2000 how to.
  • The procedure may vary from Sony model to model. These procedures are for Sony Rear Projections only. For other models, please consult your manufacter's website. All rear projections have the option of reseting the lamp hours. This helps since you will know how many hours your last lamp ran for. Normal lamps should run between 5000 to 8000 hours.
    Try the following procedure:
    Please be cautious when entering service mode. Following the information below and you will have no problems.
  • Enter service mode by pressing Display, 5, vol +, Power On.
  • Proceed to the Option-E screen by pressing the 2 or 5 button
    Option-E 0 0
  • Change data to 1 using the 3 button on the remote
    Option-E 0 1
  • Press Mute Enter to write data.
  • Jan 26, 2011 | Televison & Video
    Replaced the projection lamp, it is still saying that it is ending reaching the end of its life, Is there a reset button?
  • 1
  • 2
  • 3
    Option-E 0 0
  • 4
    Option-E 0 1
  • 5
  • Oct 29, 2010 | Sony Grand WEGA KDF-55XS955 55" Rear...
    Lamp is at it's end and I need to reset new one. How do I do it at home
    Hi, you should have a reset procedure in the instructions that came with the new lamp, if you didn't most of the lamp suppliers will give you tech support either on line or by phone for the reset procedure. If you have trouble getting the procedure try the following link: http://911phone.net/Panasonic_TY-LA1000_Instruction_Manual[2].pdf
    Oct 20, 2010 | Panasonic PT-44LCX65 Television
    The TV resets itself every 30 seconds , I have turned it off I have also unplugged it and plugged it directly into the wall as well as change out surge protectors. the TV will be fine for a day or two then...
    If it is Sony KDF-E42A10 TV then it needs new lamp.
    How old is this TV and have you replaced lamp recently?
    Lamp replacement procedure is written in user manual.
    Let me know to provide you more info.
    Thanks.
    Oct 01, 2009 | Sony KDF-E42A10 42 in. LCD Television
    Replacing the projection lamp
    Try resseting the lamp timer following the info below: Procedure for resetting the KDF42WE655, KDF50WE655, KDF55WF655, KDF55XS955, KDF60WF655 or KDF60XS955 lamp timer:
    1. Press the JUMP button 3 times on the remote to get to the Panel OSD mode.
    2. Next press the remote channel 2 button 9 times to get to the Lamp Timer mode.
    3. Press the remote 3 button, mute, then enter to reset the timer to zero.
    It will take 45-50 seconds for the timer to reset. After the timer is reset you can shut the TV off. The lamp timer will remain reset (no need to save).
    Dec 05, 2008 | Sony Grand WEGA KDF-55XS955 55" Rear...
    Reset after using emergency close feature
    Hi jimmac123
    Where exactly in the UK are you ? I'll try and locate another - more helpfull company.
    May 20, 2008 | Sony VPL-ES1 Multimedia Projector
    Sony Grand WEGA KF60XBR800 60" Rear Projection Television Logo
    Top Sony Televison & Video Experts
    Nasir Muhammad
    Nasir Muhammad
    Demonic-2011
    Demonic-2011
    Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
