Question about Whirlpool RBD305PD Electric Double Oven
SCHEMATIC FOR GBD307 OVEN
NOT WORKING AT ALL
  • 6073 Answers
SOURCE: Display E2 and F3-oven locked automatically on a Whirlpool built in oven GBD307
The F3 E2 error means that the oven high temperature sensor is reporting an over-temperature event. This could be a problem with the sensor, the oven control unit or the wiring. The oven needs to be unplugged (or the circuit breaker turned off) and then you can check the sensor. Since this is a built-in oven, you may want to get a professional to look at it. The oven has to be pulled out of the cabinet; if you do it yourself, make sure to get another person to help.
You need to open the rear access panel that covers the control (ERC) and the lower panel over the back of the range. Then find the sensor and trace it's wiring up to the ERC. Disconnect the wires from the ERC. Then with a multimeter, check the resistance of the oven temperature sensor. It should give a reading of 1000-1200 Ohms. Then the ERC may be faulty.
However, some people report that just disconnecting and then reconnecting the wiring will solve the issue. In that case, a bit of debris may have gotten into the wiring harness.
I hope this helps.
Posted on Jan 20, 2015
Whirlpool gbd307 why will The upper oven not work but the lower oven works
Have you checked the heating element supply voltage with a VOM? And have you checked for a popped/burned fuse to the bake element?
Aug 06, 2014 | Whirlpool GBD307PDS Electric Double Oven
Why my whirlpool GBD307 double oven top oven will not cut on, but the bottom one will. but after heating up, the oven starts blinking the start? button but it will not cut off, it shows a error code F
that's a bad touch panel or key panel,the number you sent isn't the full model number off of the oven so when you call to order the part you will need that.if you try to fix this yourself make sure the power is off.good luck
Nov 07, 2017 | Whirlpool GBD307PDS Electric Double Oven
Getting a E6 F2 error code on my Whirlpool GBD307 Oven
F2 - E6 Cancel key drive line open1. Check keypad connector for firm connection (keypad connects to control board).
2. Press CANCEL. If error code returns after 60 seconds, replace keypad (also called touch pad or membrane switch). Some models incorporate keypad in to control board as one unit. In this case, replace control board (also called ERC or clock).
Nov 26, 2010 | Whirlpool Ovens
GE double convection oven model GBD307 has stopped working.
my bake element stop working it is hidden and can't find out where i need to replace it,whirpool can you help
Dec 19, 2009 | GE Ovens
Ilost my manual for my whirlpool selfcleaning oven Accubake DUO how do i clean it
Hello Su Flynn,
Here's the page with the owner's manuals that you can download for free. Just click on your particular version of the GBD307 Series ovens, as there are several variations of them!
http://shared.whirlpoolcorp.com/product_literature/search_results.jsp?searchTerm=GBD307&siteCd=MT_EN_US
You can an electronic copy of it and print it out if you wish.
Again, just chose your version from the list I provided the link to and you'll be all set with having all the instructions needed for cleaning, along with use and care guidelines that you'll find helpful.
Hope you find this Very Helpful and best regards!
Dec 10, 2009 | Whirlpool GBD307PDS Electric Double Oven
Whirlpool Gold Series double oven electric model GBD307-PDQ309
Usually this is a touchpad and control panel fault but the only way to know for sure is to do some electrical testing with a volt/ohm meter and the wiring diagram located within the appliance.
With the model number of the oven we could look up the code and be more specific about the problem.
Go here for: http://www.repairclinic.com/Whirlpool-Range-Stove-Oven-Parts
RepairClinic.com
asplogo.jpg?ver=23
appliance parts, help & more
Apr 09, 2009 | Whirlpool RBD305PD Electric Double Oven
How do I get into the fuse to change it on my whirlpool GBD307 PDQ7 oven? Where is it located?
There are different fuses, a fuse is located on control assembly board, a thermal fuse is accessible removing a panel at the back of the oven, or inside the oven.
Enter here to find assembly diagrams and parts for your model.
Contact the seller by phone if part is not listed on the website.
Jan 02, 2009 | Whirlpool GBD307PDS Electric Double Oven
Whirpool GBD307 - Display not working
We had the same error codes F2 E6. We were told to turn off the breaker to the oven for 5 minutes and then turn it back on and it will reset itself. We tried it and it worked! Whirpool wanted to send someone out on a service call. Thank goodness we didn't!
Mar 28, 2008 | Whirlpool RBS245PDS Electric Single Oven
Whirlpool RBD305PD Electric Double Oven Logo
15 people viewed this question
Top Whirlpool Ovens Experts
John Tripp
John Tripp
Marvin
Marvin
Are you a Whirlpool Oven Expert? Answer questions, earn points and help others
