DCS (WOTD-227) Double Oven Logo
Question about DCS (WOTD-227) Double Oven
Dcs double wall oven probe light keeps beeping even after the oven is turned off
5 Related Answers
Anonymous
  • 1952 Answers
SOURCE: DCS Built in Double Oven
click this link get manual
http://www.retrevo.com/s/DCS-WOS-230-review-manual/id/886dj888/t/1-2/
thanks for fixya
Posted on Sep 24, 2008
Anonymous
  • 725 Answers
SOURCE: DCS double wall oven model WOSD 230 totally dead during first self clean
let me know if you don't get the solution... thanks
Posted on Sep 28, 2008
Anonymous
SOURCE: Dim LCD's on DCS Double Wall Oven
Had the same problem last week - called DCS (which automatically transferred me to Fischer-Paykel) and was able to order the part from them.  They knew exactly what it was, and shipped to me in CA from CA, it was less than $90.  Just installed it, and the new one works swell.  One suggestion - I drew with a Sharpie on one side of each of the three parts that plug into the board to help align the new one, and to install the wide ribbon cable (not really a cable, but you'll know what I mean), pull up on the two side pieces and the ribbon pulls right out.  Keep it up and slide the new one in and then push the black piece down.  That was the only part that took me a minute to figure out.
Posted on Oct 04, 2008
Anonymous
SOURCE: dcs oven display dim - need part #
I just did this same repair...same part number as above (Part #211696 "Electronic Oven Control, Double).
to install you have to remove two screws on the top of the display section of the oven, as well as several screws on the bottom of it, and the screws holding the close pin/temperature probe socket.
Then you can pull off the whole top section (slowly) and remove the two connectors to the existing control unit.
Then release the ribbon cable connected to the control unit on the inside of the top section (press the two small pins inward and slide up the small front section of the black socket to release the ribbon connector.
Unscrew the old control panel, screw in the new one, connect the ribbon, and then reverse removal steps. Easy!
Posted on Jan 21, 2010
Anonymous
SOURCE: DCS elect wall oven LCD display
Had the same display issue with my DCS WOS-230. The display was fading and made it very hard to read clock and temp setting. Called DCS/Fisher Paykal and was told I need the Control system kit for $335.00 to fix the issue. After reading the input on this issue on this site I pushed them to sell me just the DCS EOC 211696 double display module 100-01095-00. Install took 10 minutes and everything works great. Thanks all for laying the groundwork as DCS will really push hard to sell you the more expensive kit that you do not need.
Posted on Oct 04, 2011
2answers
No heat in either oven
DCS by Fisher & Paykel
5900 Skylab Road
Huntington Beach, CA 92647 spacer.gif contact_general.gif spacer.gif 888.936.7872
949.790.8900 spacer.gif contact_tech_support.gif spacer.gif 888.936.7872 spacer.gif contact_service_parts.gif spacer.gif 888.936.7872 spacer.gif spacer.gif contact_tech_questions.gif [email protected] spacer.gif
Where can i buy a replacement control display
Hello Friends!
This dimming vacuum display is either caused by a power supply failure with the control board, or a the filaments of the display themselves have started to wear-- similar to that of a bad light bulb. Either way, FixYourBoard.com can solve this problem- This control board is no longer available to buy new. Contact FixYourBoard.com at 512-355-1108 for more information. The photo below is from a double oven, but they repair single oven displays too.
Apr 13, 2017 • DCS Ovens
DCS double oven blinking the word "probe" when no
Check your temp probe ans see if it is not up against the wall or jammed of even broken off.
Feb 24, 2013 • Ovens
Flashing PF 32 error code
Hello - This manufacturer does not show to have such an error code for a wall oven. However the error codes F30/F31 indicates that the unit either has an issue with the oven sensor, wiring with the EOC or the probe connections is open or shorted. Contact a professional to move forward accurately.
Need a service manual for wo-127ss DCS single wall oven. need to replace the control board because my display light went out. How do I take it apart?
you can call dcs, they will be happy to send you a manual,
but mostly, this should be pretty simple, three small black phillips heads hold tthe console down, the are above the door when closed
from there the panel should tilt forward and off
becareful they dont leave much room. or very long wires
2answers
F7 error message in DCS 27in double electric oven
hello. here is the customer service department info at DCS. Since this unis is new, Irecommend that you work directly with them so as to avoid voiding the warranty
http://www.dcsranges.com/contact.html
9helpful
5answers
Top DCS Ovens Experts
vince
NOEL
NOEL
Are you a DCS Oven Expert? Answer questions, earn points and help others
