Converted my bmw e30 325i form auot to manuel
You need to jump the neutral safety switch there was a plug you disconnected in front of the shifter it has either 4 or 6 pins, take the plug you pulled out cut it off of the old gear selector and plug it back in and strip the wires back, the wires are color coded so like colors usually go together. with a 12 volt test light ground the clip to a proper ground, turn the key to the start position hold on start and check for voltage at the wires you previously stripped, let go of key and voltage should stop if voltage is constant you may be on the reverse light circuit, keep looking for voltage that goes on only when key turned to start, when you find it look for the corresponding color ie green /white to green/ black etc, wire the 2 together and starter should crank over, if not try another one. you will also need to wire the reverse light switch from the new trans to this connector. stay away from brown wires as they are grounds on bmw and never hook anything but brown to brown unless you are 100 percent certain it hooks up that way
