Question about KitchenAid KWVU205YBA Kitchen Hood
How to replacd fn motor on kitchenaid range hood m# kwvu205yba0
Blower is working, but makes a medium to high pitch sound
Blocked or dirty filters or grease buildup on the fan blades. It may also be the bearings in the fan motor are wearing out. Most rangehoods , only have the motor assembly as a spare part.
Sep 17, 2015 | KitchenAid KWCU205HSS Kitchen Hood
The unit has power going in but acts as if there is no power
I would be rechecking my connections fast before something catches fire
May 23, 2014 | KitchenAid KWVU265YBA Kitchen Hood
Removing blower motor
tap the fan on the shaft just a bit then clean the shaft with sand paper then carefully pull and rotate the fan off of the motor shaft = lock the motors rotor in a vice this make it a easy job. BUT don't damage the fan ! if it feels like it's not going to come off STOP. and search for you local electric motor repair shop with free testing. and ask him to pull it off fer ya, ask him how to oil this motor so you don't go threw this again. ?
Jay the pool pump motor repair guy in longwood Florida 32750
Feb 08, 2014 | KitchenAid Kitchen Ranges
Kitchenaid range hood uxb0600dys wiring schematic
I don't mean to be rude, but wiring this hood without a schematic should be simple for a qualified electrician. Perhaps you should pass on this and hire one.
May 20, 2013 | Kitchen Ranges
KWCU405SSS fan motor high speed only
Agreed! It totally works. Our fan and lights were stuck on high. Flipped the hood circuit breaker off for 30 seconds then back on again and all controls are working normally again. Thanks!
Jan 15, 2013 | KitchenAid Architect® II KWCU405SSS...
KitchenAid KHTU160KSS Kitchen Hood makes noise
Remove the fan and motor assembly from the hood (the fan motor will plug into the hood housing) and using an electrical motor cleaner (such as CRC electrical motor cleaner available from your local auto parts store) wash the motor and fan as completely as possible, lubricate the end bearings (sparingly) with a very light oil such as sewing machine oil, gun oil or as a last resort 3 in 1 oil. Hope this helps.
Dec 14, 2011 | KitchenAid KHTU160KSS Kitchen Hood
How to remove nuts that secure blower wheel to fan motor
The set screws do not have to be removed... just loosened...
Getting to them is the tricky part...
often there is a hole in the blower wheel fins so that you cn get tools into the set screws..
heatman101
Apr 27, 2011 | KitchenAid KIRD801HSS Kitchen Hood
Our Kitchenaid Range Hood model KWCU405SSS has a code "C" in the display. What does that mean?
I just did this and it works.
1.) Make sure to turn off both the fan and the lights. If you skip this step the next step won't work.
2.) Press and hold the + button for 4 seconds until the "C" disappears.
Repeat in another 100hrs of use.
Mar 19, 2011 | KitchenAid Architect® II KWCU405SSS...
Kitchenaid hood wont allow reset of "C"
Try presing the "+" button for four seconds instead...
Mar 20, 2009 | KitchenAid KICU265HSS Kitchen Hood
KitchenAid KWVU205YBA Kitchen Hood Logo
93 people viewed this question
Top KitchenAid Kitchen Ranges Experts
Jay B
Level 1 Expert
Colin Stickland
Colin Stickland
Marvin
Marvin
Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
