Question about Kenmore 45981 Washer
Error code I'm getting a failure code when I attempt a cycle. F DL. What does this mean? How can I fix this? Thank you!
Posted by Big Toe on
  • 1 more comment
  • Big Toe Nov 01, 2007
    The model # is 110. 45981 400
    Thanks!
    Thanks!
  • Anonymous Nov 01, 2008
    I have the exact same problems. I will use the fixes listed in the previous posts. Thank you for the help
Jeff Rockwell
  • 5,911 Answers
Fdl is a door latch error.  What it means is that the Central Control Unit (CCU), which is the main computer, has lost communications with the door latch.  If you can't hear the latch clicking when you try to start a wash, chances are the door latch is broken.  Sometimes they will click,  but the internal latching mechanism may be damaged.  If the door latch fails to close, the washer will not begin a cycle.  If you provide me with your model number (located along the inside of the door) I can get a part number, price and where you can get a replacement.  I can also give you step-by-step instructions on how to replace the latch.  This is a fairly simple problem that the do-it-yoursefler can accomplish with a little guidance.  Let me know.
Posted on Nov 01, 2007
  • Jeff Rockwell
    Jeff Rockwell Nov 01, 2007
    The part number is 1094190, with a price of about $50. You can order the part on line at repairclinic.com. You will have to pay extra for shipping. Just enter your washer model number and a pictorial parts index will be displayed. Choose your part and method of shipping. Standard shipping usually gets the part to your front door in about 5 to 7 days. Now, if you still want to pursue the repairs yourself, follow these steps:
    1. Unplug washer.
    2. Remove the outer portion of the door bellow. This is the gray rubber boot around the door. Feel around the edge of the door bellow where it attaches to the front of the washer. You will find a wire retaining hoop in the seam between the rubber and the front case. Follow this wire hoop to the bottom of the door bellow and you will find a tension spring. Carefully, stretch this spring apart and remove the wire hoop.
    3. Pull the rubber bellow from the door facing on the front of the washer being careful not to rip or tear it. Once removed, fold the rubber backwards inside the drum so you can access behind the front panel. DO NOT remove the rubber bellow from the wash tub. This requires more steps, which means removing more parts, which means more time (plus patience).
    4. The door latch assembly is located behind the front panel of the washer on the right hand side. Locate and remove the three screws on the washer front that hold the door latch assembly in place. The whole assembly should come free from the washer front and be held by a plastic mounting bracket and several wire connectors.
    5. Carefully remove the latch assembly from the plastic mounting bracket BEFORE attempting to unplug any wires. It makes it much easier to access if you do.
    6. Unplug the wire connectors using care not to break any of the wires. You may want to write them down, but I believe they will only plug into their respective slots.
    7. Remove the old door latch and install the new one in the reverse order of the steps I just presented to you. Plug the wires back in first, then place the whole assembly back into the plastic mounting bracket, then reattach to the front of the washer.
    8. Now, when you get the the reinstalling the rubber door boot, you may want to get the assistance of a second pair of hands as it can be difficult sometimes to manipulate the wire retainer back into place. Carefully reattach the rubber bellow to the door facing on the front of the washer first.
    9. Starting at the top of the door bellow at the 12 o'clock position begin inserting the wire hoop back into the groove. Work your way around with both hands to the 4 and 8 o'clock positions. (This is where you could use those second pair of hands). While holding a slight downward tension on the wire hoop to keep it in place, pull the tension spring apart enough to snap the remaining part of the hoop into place at the bottom.
    Once you've completed these steps make sure the door closes and latches properly. NEVER slam a door with an electronic latch. They can break easily.
    Now plug the washer back in. At the control panel select:
    DRAIN SPIN
    NO SPIN
    and under OPTIONS press any key (has the be the same key) 4 times.
    This places the washer into diagnostics mode. "C00" will be displayed on the screen and you should hear a distinctive "click" of the door latch. If diagnostics passes, the washer will run through a series of tests, tumble, drain and then spin. When completed, the unit will make an audible "beep" and the CLEAN light will be lit.
    You can stop this process at any time by press the PAUSE/CANCEL button. Good luck to you and let me know if you have any further questions.
Anonymous
    Problem Solver:
  • 4 Answers
Open the front panel of your washer and you will see the manual guide there.
there will be a list of error code
Karl Whisenand
    Genius:
  • 1,554 Answers
Http://www.fixya.com/support/t364216-whirlpool_duet_ht_ghw9400pl0
Posted on Mar 31, 2008
Hi - my washer machine stops mid cycle then beeps and shows a dL code. what does this mean? How can I fix this?
Listed below is the meaning off the error code, and corrective actions needed.
FdL Door lock error A Door Lock Error occurs if the door cannot be locked. It will try to lock it 6 times before displaying the error.
Potential Causes
• Door Lock Mechanism broken or removed from the Door
• Check Door Lock/Switch Assembly
• Check the wire harness connections to the Door Lock/Switch Assembly and Central Control Unit (CCU)
• Door Lock/Switch Assembly Failure
Replace failed component.
If you have any further questions please feel free to ask.
Nov 17, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Will start the wash cycle and DL come on and light blinks and lid lock unlock (Whirlpool Cabrio model# WED6400SW)
"dl"indicates a door lock error. A Door Lock Error occurs if the door cannot be unlocked. It will try to lock it 6 times before displaying the error.
Check for the following when dl occurs:
  • Door Lock Mechanism broken.
  • Check Door Lock/Switch Assembly for foreign objects
  • Check Wire Harness connections to the Door Lock/Switch Assembly and Central Control Unit (CCU)
Thank you !!
Jul 28, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
I am getting the code dl and F on my whirlpool duet washer model # GHW9150WO
"dl" indicates a door lock error. A Door Lock Error occurs if the door cannot be unlocked. It will try to lock it 6 times before displaying the error.
Thank you
Jul 17, 2010 | Whirlpool Washing Machines
Error code
Thank you !!
Jul 09, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Washer wont turn on. code is F dL. any thoughts?
Thank you !!
Jul 07, 2010 | Whirlpool GHW9400SU Front Load Stacked...
Door is locked dL error code
DL error code means the door is locked. The door lock mechanism may need to be replaced. I would not recommend attempting this on your own I suggest you call a service tech.
Mar 17, 2010 | Kenmore Elite 45986 Front Load Washer
Washer wont engage
The door may not have been fully closed. stop/clear cancel the cycle. ensure door is fully closed and attempt to resart cycle.
F/dL Door Lock Error
Feb 08, 2009 | Kenmore HE2 Plus Front Load Washer
Error code DL...
DL indicated a door lock failure. it will flash DL, then a F followed by a number (80, 82, 84, 85)
Jan 24, 2009 | Kenmore Oasis HE 27082 Top Load Washer
I am getting an DL F code on my front loader
"dL" indicates Door Lock Failure: dL flashes if the following conditions occur:
Door lid is not closed completely due to interference.
Wash media buildup is preventing the lock bolt from extending.
Machine/motor control detects open door lid switch when attempting to lock.
Machine/motor control cannot determine if door lock is in a locked state.
Check for lock interference with lid or lock bezel
Jan 04, 2009 | Kenmore Elite 45986 Front Load Washer
Cycle wont start then I get Error / dl
the dl code is a door lock error,open door and examine door lock assy mounted on front panel.look for a plastic push pin approx 5inches up from square lock assy.if that pin is missing,replace door lock.if pin is there,you could still have bad door lock or loose wire connected to door lock.
Sep 23, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore 45981 Washer Logo
168 people viewed this question
Harvey Mahal
Kristen Denison
Kristen Denison
Level 1 Expert
Will Mishler
Will Mishler
