Question about Samsung HT-Q70T System
Power on and Get the Display panel lights up like christmas
When I power on the home theater, all the display light lights up and then it powers off.  My guess is it's a short but any suggestions besides that.  Thanks
Posted by jrad1 on
Anonymous
    Genius:
  • 1,027 Answers
That is an internal fault, with it's power supply. They shutdown if an in-balance is detected.Also check the speaker wire connection - will do the same thing if disconnected or shorted.
Posted on Jul 04, 2008
No power output or display.green standby light flashes.
Sounds like either a blown mainpower fuse or the thermal fuse for the power transformer. If the protect circuit was kicking in, the display would light up, but then turn off with a red blinking light. the green light with no display means the transformer is not getting power.
Dec 31, 2013 | Denon Avr-1610: 5.1 Ch A/V Home Theater...
I have a Bose Lifestyle 25 series II system and the display is dark and will not light up. Are ther bulbs in there that might be burned out or what do I need to do to fix this problem so the display...
Had the same problem. The electrolytic capacitors on the power board were not well - I tested a few of them and ESR values were all high. One of my 100uF caps was open circuit and not charging. I replaced all caps on the power board and display is fine again. Hope this helps.
Feb 05, 2011 | Bose Lifestyle 25 System
I HAVE AN LG HT44M HOME THEATER THAT I JUST BOUGHT AND AM FRUSTRATED CAUSE I JUST GOT IT FOR CHRISTMAS AND IS UNABLE TO PLAY ALL REGIONS AND CAN ONLY PLAY REGION 2. CAN YOU PLEASE HELP ME IF U HAVE ANY...
1. Opening DVD Drawer
2. Pressing "0000" on the remote.
3. A screen appears saying NEW REGION CODE and displays the current one.
4. Press "0" for all zones.
5. Press the "select" button on the remote.
6. Close the CD Drawer.
7. Power off
for recorders try this
Power on w no DVD in.
Press Setup on remote.
Highlight Lock Picture.
Press 0000000 (7x 0).
Player will display "congratulations player now region free", select OK.
Dec 27, 2010 | LG Audio Players & Recorders
I have SC-PT750 Wireless system with SH-FX65T and SE-FX65, the wireless does not work and the screen flashes W1 to W2 and the SE-FX65 red light stays on
1 Turn on SE-FX65 2 While pressing [>>/>>'] ] press the numbered button [3] on the remote control until "P" lights in the home theater unit's display The indicator on SE-FX65 turns green. 3 While "P" is displayed, press [I/D SET] 4While pressing [>>/>>'} press the numbered button [3] on the remote control.
This worked for me. I moved and lost the FX65A, and Had to buy a replacement off ebay,
Used this manual http://www.specsserver.com/CACHE/FRQUJVMNXTYS.PDF but I have to give mosyzlak props, cause he gave me the idea to look for it.
Nov 28, 2010 | Panasonic Home Theater System System
I keep getting the 'rear check' message on the tower panel display and all cables are connected what could this be this is on my new HT-TXQ120 DVD HOME THEATER SYSTEM
With the home theater system off, press and hold the REMAIN button on the home theater's remote control for 5 seconds.
Note: You can release the REMAIN button when the POWER LED blinks blue.
With the wireless module turned on, use a ball point pen to press the RESET button on the back of the wireless module. The POWER LED in the front of the home theater blinks two times.
Turn on the home theater. The LINK LED on the front of the SWA-3000 changes from red to blue, indicating the wireless module has connected to the home theater.
If your home theater continues to display rear check after you have tried the steps above, call Samsung Customer Care at 1-800-SAMSUNG (1-800-726-7864). Have your model number and serial number on hand to set up service.
Jun 29, 2009 | Samsung HT-TXQ120 Home Theater System...
Rt2280 no power up, no display, standby light works
Might be the relay on the power board that stands up just behind the big transformer. I has a complete no power also, I shorted out the relay legs on the black one, it started to work again. I will probably replace it, since the problem started by the system shutting off randomly.
Oct 19, 2008 | RCA RT2280 System
Bose Lifestyle V20 - no video out, no response to remote control
check the voltage setting on the power supply that connects the power cord to the media center. Mine was set to 230V. Changed it to 115V and the video starting working.
Oct 05, 2008 | Bose Lifestyle V20 System - black Theater...
Getting F61 in Display of Panasonic SC-HT700
I have gotten the f61 error code on my SC-HT700. No idea what the problem is.
Aug 30, 2008 | Panasonic SC-HT700 System
Samsung HT-Q70T System Logo
53 people viewed this question
Top Samsung Audio Players & Recorders Experts
ThaMp3Doctor
ThaMp3Doctor
Marvin
Marvin
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
