Question about Avantco Refrigeration Avantco CFD 2 Door Reach In Refrigerator Stainless Steel 120V - 46.5 Cubic Feet
High out of spec - Avantco Refrigeration Avantco CFD 2 Door Reach In Refrigerator Stainless Steel 120V - 46.5 Cubic Feet
Specs for arctic king chest freezer model w8s-185c1ws how many watts does it use
Specs don't appear to be available. Freezers are usually rated in amps. To find the watts, multiply the amps by the voltage. Would also depend on the cubic feet of the freezer as the bigger the freezer, the more amps the compressor draws.
Only thing I could find is its energy star rating.
Find and Compare Products
Jul 09, 2016 | Freezers
Looking for specs (cubes) on chest freezer model MFC07M3FW0. Any one?
According this model you have a 7 cubic feet freezer.
I’m happy to help further over the phone at https://www.6ya.com/expert/gere_bf68e6055dd61249
Aug 17, 2014 | Freezers
Missing Manuals
Visit the manufacturer's website to download a manual.
Dec 22, 2013 | Freezers
Sub zero ice maker jz235p0 specs
Call the mfr or ask them for the website that has the specs on it.
Mar 04, 2013 | Sub-Zero Sub Zero Icemaker
Specs of tev for mccall freezer
you need model number and serial number . refrigerant type and possibly the compressor model number to determine the txv type and capacity
Nov 26, 2012 | McCall Refrigeration Commercial Freezer...
Looking at new freezer, what is the difference between Turbo air TSF-23sdr and TSF-23nm? product specs would not download. thks
Do you mean the MSF-23NM and the TSF-23SD? If so, you can find the information for them here:
http://www.turboairinc.com/TB-Products/Soliddoor.html
Basically, the difference between the two is that the MSF-23NM runs on more amps and is a new "maximum" series that Turbo Air came out with.
http://www.missionrs.com/MSF-23NM.html
http://www.missionrs.com/TSF-23SD.html
The product spec sheets at the two links above should be easy to download from our site. If you have any trouble, you can call us at 1(800)319-0690.
Sep 22, 2010 | Turbo Air 23 cu. ft. / 651 liter...
Freezer begun tripping our 20 amp breaker for some reason
ok hi there i viewed the specs for this freezer
http://www.truemfg.com/catalog/servlet/com.apsiva.servlet.HomeServlet
this unit must be plugged into a 120v outlet with a 15amp circuit breaker dedicated (nothing else should on this circuit) so all by itself. you have to check the voltage outlet where you plug in. you must have at least 115v or better (125v the most) if you have less then 115v it will cause damage. ok you went and checked all this out and everything is 15amp with 115v or better and it still trips breaker.
ok the running amps is 6.8 amps so to blow the circuit you need 15 amp which is too high.
i suggest you call a refrigeration guy because he will be able to determine if the problem is the compressor (which has a 4 year warranty with truemfg.com only in the USA) or something else. Usually but not 100% what would make a freezer like yours to blow the fuse is the compressor. if it overheats it will do this, if there is a sudden high pressure within the system it will do it, if you have a condenser fan that is not running at proper speed it will do this...
the problem cannot be pin pointed understand please... you have to babysit it, watch for changes in the refrigeration system and the running compressor amps, voltage drops ( this will cause high amps) etc...
Refrigeration is not easy and alot of tech stay away... so those who stick it out make money cause you have 2 choices: buy another one and pay big bucks to get it fixed. at least see if you can find someone to come over (for like $40 - $60) and tell you exactly whats wrong with it... whew... hope this was helpful and not confusing...sorry
Apr 03, 2010 | True 19 cu. ft. / 538 liter Commercial...
Need -20 degrees Celsius...Will this brand get there?
If all is ideal maybe -10 an occationally -15 and this is F considerable coolder than -20C. ALSO fyi a chest freezer will stay at or below these temps better than an upright and especially a self defrosting model. Because a chest freezer you dont loose all the cold air when you open the door. TYhey are not made in auto matic defrost as far as I know (never have seen one but then I havent been looking for one either. An up right freezer can be manual defrost or automatic. but the cold air falls ouit every time the door is opened.
Please let em know if this helps you by giving me as high a mark as you can and thank you for using fixya.
May 29, 2009 | Kenmore 24.9 cu. ft. / 705 liter Chest...
Avantco Refrigeration Avantco CFD 2 Door Reach In Refrigerator Stainless Steel 120V - 46.5 Cubic Feet Logo
76 people viewed this question
Top Avantco Refrigeration Freezers Experts
Dennis Boxerman
Muntejaya Ginting
Muntejaya Ginting
John Tripp
John Tripp
Are you an Avantco Refrigeration Freezer Expert? Answer questions, earn points and help others
