Question about Polaroid A500 Digital Camera
Time & date
I am having the time and date problem with my A500 Polaroid camera as noted by others Is there a solution?
Posted by meme04 on
  • 3 more comments
  • meme04 Feb 04, 2008
    No fix as of yet!!!
  • meme04 Feb 07, 2008
    I did not see afix... the person stated they were having same problem????
  • Anonymous Mar 17, 2008
    Same problem...Started around Christmas 2007. Have to re-set the Date and Time on power up.
  • netsue May 10, 2008
    My date and time has to be reset everytime I turn the camera on. As long as it is on, things are fine until it is turned off then it resets to another date. I have changed batteries with no results. Can turn the date off but when I turn the camera off and back on, the same thing happens, date is reset to an earlier date...usually 3/10/1993. I think the company needs to do a recall and make this right for all of us having the same problem.
  • jeffmarcum Jun 17, 2008
    Same problem. Mine resets to 03/10/01.
Anonymous
  • 57 Answers
What could be happening is the you mother board is bad already. Usually digital cameras like computers use a button cell battery inside to keep the bios in memory or the board uses the installed batteries to keep the bios in memory but at a very slow power consuption rate. Everything comes down to pretty much a bad circuit somewhere that is causing memory lost and high consuption of battery power.
Also i've noticed that a lot of people with this camera is having the same problem. This called be because of mass production you all could have a bad batch. Meaning your cameras came off the assembly line around the same time.
Posted on Apr 28, 2008
How do I keep the date correct?? It alway pops up
Next time you finish setting it, press the set/ok button twice.
Apr 01, 2010 | Polaroid A500 Digital Camera
I am trying to locate the owner's manual for the Polaroid a 500 digital camera. Is there one available. Thank You for your time. Best Regards, Robert
Copy and paste this address in your browser...you can download the manual to your computer. http://www.nodevice.com/user_manual/polaroid/digital_cameras_and_frames/a500.html
Feb 15, 2010 | Polaroid A500 Digital Camera
Can't set the date polaroid a500
It looks like the date battery has dried out, check your user manual and try to replace with a new button battery.
Jun 04, 2009 | Polaroid A500 Digital Camera
My D.C does not keep the date
Exit the menu that comes up about time & date when you turn it on. Then press the menu button, use the left navigation button, then scroll down to date & time, and set it there. For some reason when it comes up the navigation buttons won't let you set the time, but when accessed from the menu, it will.
May 21, 2009 | Polaroid A500 Digital Camera
Setting the date and time
Mar 09, 2008 | Polaroid A500 Digital Camera
Time & date reset
Very often the date/time is maintained by a very small watch type battery built into the main board - there is no opportunity to replace this.
Dec 29, 2007 | SVP DC-12D Digital Camera
Polaroid digital camera a500
i cant get my vpc t-700 digital camera from saying no image i need to save my pictures thank you
Dec 28, 2007 | Sanyo Xacti VPC-T700 Digital Camera
Time and date
There is a small 3volt battery soldered on the main board that needs to be replaced. It has a yellow band around it, unless you can replace it yourself it's not worthwhile. If you decide to replace it beware of the flash capacitor charge.
AL
Sep 17, 2007 | Polaroid A500 Digital Camera
Date & time
My camera will not turn on either. I have only used it a couple of times. This is my first time to buy a polariod. I hope we have a solution for this problem. It seems as thought many others are having the same problem, and no one is doing anything to help. Please reply with some sort of solution besides taking it to a pc store. I just bought this, I don't have a receipt, so what is the answer? Thankyou!
Aug 31, 2007 | Polaroid A500 Digital Camera
Polaroid A500 Digital Camera Logo
50 people viewed this question
Top Polaroid Cameras Experts
Ekse
Lee Hodgson
Lee Hodgson
Marvin
Marvin
Are you a Polaroid Camera Expert? Answer questions, earn points and help others
