Question about Panasonic PT-50LC14 50" Rear Projection HDTV-Ready Television
Clean the filter air
In the HDTV legend appears. that said clean air filter. how I clean the filter air
5 Related Answers
Anonymous
  • 927 Answers
SOURCE: pt-52lcx66-k multimedia projection hdtv - air filter needs cleaning
Good Day,
It sounds like your lamp sensor is defective. Change it and it should correct your concerns. I hope this helpful.
Posted on Jun 11, 2008
Anonymous
SOURCE: Air Filter message
Soulvisitor has it right. I had the same problem and the stupid tv would shut off after 1 minute. We opened the silver front panel , took the bulb out cleaned it, took the cover off the grey box to the right and very carefully vaccumed the filter and wiped it off with a microfiber cloth. It works great now!!! Make sure you unplug your tv before messing with it. Thank you Soulvistor you saved us at least $100.00
Posted on Nov 04, 2008
Anonymous
SOURCE: how to the clean the air filter
where is the air filter located in the tv
Posted on Dec 05, 2009
Anonymous
  • 19 Answers
SOURCE: how do i clean the air filter in my pt-50lc14 tv ?...
hi here u solution, no easy, but u can try,good look :)http://schematicsforum.com/schematics//TV/Panasonic/PT-50LC14.pdf
Posted on May 27, 2010
Anonymous
SOURCE: An OSD advising "AIR FILTER CLEANING" is displayed
I had the same problem, service center said it would cost over $1,000 to perform the work. Buy an new TV and move on, After replacing three lamp assemblies in five years and now this I'll never buy a Panasonic again!
Posted on Nov 12, 2011
2answers
Reset air filter
Page 58 of the user manual says that after cleaning the filter when the power is turned on, you will be given the opportunity to reply "Yes" to the question "Did you clean the filter". I suggest you go through the motions of cleaning the filter again, removing the necessary parts. Then replace the parts, turn the power on, and watch carefully for the message "Did you clean the filter".
Clean filter message reset
the filter will need to be cleaned and if the set still shuts down then I would suspect the fan may need to be cleaned and possibly replaced.
My legend is hard to start after i go places and try to start it back after half hour it dont want to start
AIR FILTER CLOGGED, CLEAN FUEL INJECTORS FILL UP GAS TANK 3/4 TO FULL TANK OF GAS POUR BOTTLE OR CAN OF SEAFOAM IN FUEL TANK SEE IF IT HELPS PROBLEM.
I get a message to clean filter. I removed back but could not find filter. Cleaned all visible dust and reinstalled back. Worked great for 2 months and got message again. Next day worked ok again. ...
hi,
To clan the air filter you have to remove the projection unit.You can see the projection unit behind the lamp blast board.There are three air filters in this unit. You have to clean these air filters. I have added the picture which showa the location of air filters. If you can give your email address the i will sent the service manual. Which will help you to remove and clean these Air filters. Remember one thing remove lamp first then only remove the projection unit from the rear side.
OK
2answers
LOCATION OF AIR FILTER, AND HOW CAN I TAKE OUT THE...
how can i clean the air filter element, and where is it located
5helpful
2answers
Warning light comes on that T.V. will shut off in one minute & to call a technician to clean air filter.
Sounds like a plasma, or projection system. Find the fan inlet filter, remove the foam filter, and vacuum with a dust buster. You can use a can of compressed air to blow the filter clean, too.
Clean filter
In order to clean the air filters properly. The projection unit must be removed from the rear. This unit is very expensive! I would recommend calling for service. But you can find the service manual online for free if you feel daring.
Panasonic PT-50LC14 50" Rear Projection HDTV-Ready Television Logo
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Ekse
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
