Question about Canon BJC 80 InkJet Printer
Slow printing my bjc 80 takes about 5 minutes to print between each page. It is connected to my dell lap top running xp
Posted by Dinolg on
Anonymous
    Problem Solver:
  • 18 Answers
Purchase a PCMCIA parallel port adapter. the USB to parallel adapters are a pain to set up and are flakey at best. The PC card adapter provides a native parallel port to laptops without one, and works perfectly in ALL cases, even with the scanner cartridge. In Vista, the printer may then be manually installed from its list of printers, and set to use the new LPT port.
Posted on Aug 20, 2009
Canon BJC printer keeps printing test pages
Printers with USB are so inexpensive and think you have an incompatibility issue with your BJC-80 and the usb to serial convertor is not helping.
http://www.ebay.co.uk/sch/Printers-Scanners-Supplies-/171961/i.html?_from=R40&_nkw=printer&_sop=15
Hope that helps.
Mar 19, 2014 | Canon Office Equipment & Supplies
Trying to hookup bjc 80 to acer aspire 4730z running vista, don't have disc but am hooked up via usb.
you need the printer driver for vista in order to be able to print out. But Canon does not offer drivers for XP and Vista for bjc-80, however you can manually install the driver for BJC-85 and get the printing function going, but the scanner cartrige does not work through USB.
BR
Bruce
Oct 23, 2009 | Canon BJC 80 InkJet Printer
What does disabling bidirectional support mean
Normal 0 MicrosoftInternetExplorer4 st1\:*{behavior:url(#ieooui) } /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} USB to Parallel conversion requires translation by XP and Vista's 'hardware interleave' software as well as the USB device manufacturers driver. The software package just doesn't work well with older peripherals that use legacy parallel or serial com ports. Too many sloppy layers.
THE BEST WAY to add an LPT printer port to your laptop is to use a PCMCIA to Parallel adapter card.
The PC Card slot provides access to the laptop's data bus, and the PC Card adapter easily sets up as a native LPT port within almost any OS.
There is no delay, or connection problems as I've seen in so many complaints about USB to Parallel or Legacy Serial adapters. Printing is Instant.
PCMCIA is a mature standard, and works seamlessly with XP and Vista, and almost any other OS.
PARALLEL is the old standard fast data protocol. IEEE 1284 ECP mode up to 1.5 Mbps.
The BJC-80 and the BJC-85 have the same print speed. The BJC-85 just added USB.
INFRARED is ver 1.0 on the BJC-80, and printing is a bit slower at 115.2 kbps. Even the BJC-85 with its higher IRDA transfer rating and a laptop's built-in IR port, the XP print spooler has problems with it, and can hang if printing more than one page, and especially with more than one document. It will not scan.
I use IR for printing single pages only with either the BJC-80 or BJC-85.
USB to IRDA adapters work fine, and are less expensive $5-6 than
PCMCIA to Parallel adapters, $20-25.
I have tested and used several PCMCIA adapters from different manufacturers, and they all work perfectly as a hot-pluggable, instant LPT and/or Legacy Serial port for my laptops.
TIPS:
After installing the PC Card driver, check Device Manager for the LPT port number.
Install the printer manually from the list of printers, and select the proper LPT port.
Most laptops have two PCMCIA slots. If you change slots, the adapter card driver may reinstall, and assign the next available LPT port, LPT2.
To scan with the BJC-80, you must have an LPT port.
The PC Card adapter also allows the use of the IS-12 scanner cartridge within XP or Vista.
Within Vista, set the Canon ISScan software to run in Windows 98 compatibility mode, to allow use of the TWAIN driver.
Jun 12, 2008 | Canon BJC 80 InkJet Printer
Canon BJC 2000 question-1284 to usb
TIPS:
Jun 05, 2008 | Canon BJC 80 InkJet Printer
BJC 80 Won't Print
Try disable bidirectional support
Jun 02, 2008 | Canon BJC 80 InkJet Printer
I HAVE A CANON BJC-85 BUBBLE JET PRINTER AND IT RUNS BUT DOESN'T PRINT.I ALSO CAN NOT GET IT OPENED TO CHECK THE CARTRIDGE. THE POWER LIGHT DOES COMES ON. MY COMPUTER IS A LAP TOP DELL INSPIRON 1525 AND...
sir,
maybe it runs out of ink it has only 5ml black and 6ml col (2ml ea. CMY) it can only print less than 50 pages., to replace the cartridge just open the cover and and wait untill the cariage is moving in the center then remove the cartidge.
yours,
alecz
Apr 23, 2008 | Office Equipment & Supplies
Slow printing
I'M USING MY BJC 80 ON A PACKARD BELL M35-U-57, VISTA HOME BASIC. CONNECTED THE PRINTER WITH A GENERIC USB-PARALELL CABLE, NO DRIVER. FIRST HAD THOSE 5 TO 7 MINUTES DELAYS FOR PRINTING. WENT TO THE PRINTERS "PROPERTIES", "ADVANCED OPTIONS" AND TICKED "PRINT DIRECTLY", IN THE "PORTS" SECTION I DISABLED "BIDERECTIONAL PORT". IT'S WORKING SWEET. NO MATTER THE QUALITY. ANY COMMENT OR SUGESTION: [email protected]
Feb 03, 2008 | Canon BJC 80 InkJet Printer
Time consuming
Try installing the latest driver: http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=230&modelid=7998
Aug 23, 2007 | Canon BJC 80 InkJet Printer
Printer won't print
I have had a similar problem to this: I have had a BJC 80 for nearly 5 years and carried it around with my laptop using Win 98 and a par - par cable. It worked beautifully and successfully - so much so that when i saw a number of ink tanks going at very cheap volume prices in PC World i picked up a lot of them. Changing to an XP meant that i had to keep on using the par to par cable via a docking station but prevented my use of it with my new laptop - so when i brought it out of retirement it gave the blank printing problems yoiu described. By checking some error messages that it expected a black cartridge (which is what was installed) i found that inthe setup the software indicated it defaulted to colour cartridges. By changing this on the computer, it still printed blank pages but by changing the cartridge to colour it sprang into life when the set up asked for colour. I tried 2 other print heads which i had (3-4 years old) but still blank paper when printing to a black cartridge. I am now awaiting a new black print head carrier to see if it makes a difference. When trying with my laptop using XP and a par - usb cable it does not work at all. I have removed the sware driver for the Canon 80 and manually installed the one for the Canon 85 but no luck in printing to par - usb at this time
S Ranson
Nov 13, 2006 | Canon BJC 80 InkJet Printer
Canon BJC 80 InkJet Printer Logo
233 people viewed this question
old marine
old marine
Ekse
Tareq Bin Mostaq...
Tareq Bin Mostaq...
