Sony Cyber-Shot DSC-P52 Digital Camera Logo
Question about Sony Cyber-Shot DSC-P52 Digital Camera
DSC-H9 mode switch repair
When you turn the mode switch it does not change and then sometimes it does. When I sprayed Blue Shower around the dial it improved. Would like to take dial off the top to get at contacts but do not know how
5 Related Answers
Anonymous
  • 551 Answers
SOURCE: Control dial -W1
That doesnt sound good :( You said the dial seems stripped,did you force it at any time? Sounds like its time to pack it up and ship it off to sony. Good luck.
Posted on Sep 15, 2005
Anonymous
  • 41 Answers
SOURCE: Flash problems
As you haven't said which shooting mode the problem occurs under (e.g. Auto, Scene etc) I can only suggest that you try different shooting modes to gain access to changing the Flash settings. Hope this helps.
Posted on Apr 29, 2008
Anonymous
  • 248 Answers
SOURCE: can i use sony cybershot DSC-H9 as webcam
no h-9 does not work as webcam,but you can shoot videos with it...
Posted on Jul 05, 2009
atang1
Arthur Tang
  • 734 Answers
SOURCE: how do I repair the LCD screen for my DSC-H9 sony ...
You need a set of philips screw drivers size #0,#00 and #000. Buy parts camera with stuck out lens but good lcd from ebay. Then replace the lcd screen and the led back light assembly connected by flexible circuit and flip up connector.
Posted on Aug 14, 2010
quintonizaak
Quinton
  • 319 Answers
SOURCE: my sony dsc-h9 will not
Do default reset
Posted on Jan 18, 2012
1helpful
How do I repair the lcd screen for my DSC-H9 sony camera that is broken and only shows a black screen with cracks throgh the lcd area
Shower/tub converter dial will not switch to
found someone else to help.....problem wasn't with airconditioner...you didn't even read my email!!
The mode selector dial on the top of the camera is stuck
Mode dial switch will be replaced as shown in below image.
You can get it from Part Store with following part number.
A-1256-816-A PW-134 BOARD, COMPLETE (SERVICE) (H9)
Thanks.
2helpful
4answers
Flash problems
4helpful
2answers
Can i use sony cybershot DSC-H9 as webcam
Just turn the dial wheel behind the shutter button to the picture where it show like a film camera. and you are ready to shoot video.
Below is the picture of the icon that you need to find.
Hope this helps.
Sony DSC-H9 optical zoom jammed
Write the camera off and buy a new one is the simple answer
unless you have a local repair shop- but parts will be the problem
2answers
Camer scrolls through modes all on its own! sony DSC W100 digital camera
very good poss that camera needs mode dial switch assembly.Especially if unit was subject to liquids near the mode dial .part # 147966811 for silver and 147966821 for black model..First reset camera by pushing reset switch should be around batt compartment and or memory stick area.
Mode switching
hmm i had this once when my camera (dsc-w70 ) was wet just heat up that dial JUST A BIT with a hair dryer or it maybe faulty > if so sony repair center
3answers
Sony DSC W7 control dial defect
I had a similar problem with my EOS 5, was trying to change between modes and it made a lovely "snapping pencil" noise and then behaved as you describe. I managed to get it done under warranty after a lot of moaning and ****(it was 54 weeks old). After chatting to some camera shop owners it seemed to be the most common problem with the EOS 5 (doesn't happen often, just most common type of error). I could understand it if I was going from the program modes to the creative modes where you have to pass through the "lock" position, but I am sure that I wasn't. Anyway, upshot was that it got fixed, works fine now, but when changing modes I always depress the "lock" button, even if its not passing through the "lock" position. Sorry, but the quick fix is pay the $75 which doesnt seem unreasonable, or switch to a camera that doesnt use that type of switching method, EOS3, EOS1, EOS D3 :-). Hope this helps to answer your question
Top Sony Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Marvin
Marvin
Are you a Sony Camera Expert? Answer questions, earn points and help others
