Question about Pioneer DEH-P4000UB CD Player
Pioneer deh-4000ub Faceplate - Pioneer DEH-P4000UB CD Player
5 Related Answers
Anonymous
  • 148 Answers
SOURCE: Screen behind faceplate stopped illuminating/working
The ribbon cable has gone bad. A new one can be ordered direct from pioneer at parts.pioneerelectronics.com Good luck!
Posted on Nov 05, 2006
ampman
Mike Ryan
  • 98 Answers
SOURCE: Pioneer DEH-P6900UB
make sure that you have power not only to the red wire but also the yellow wire... one is battery power the othe ris ignition on power. If it only is getting one power it might not think the ignition key is on.. also maks sure there is not a reset button somewhere that you can press with a pen...
Posted on Aug 27, 2007
Anonymous
SOURCE: can pioneer faceplates interchange?
no i wouldnt do it i put my 980bt on a 8600? and now both cd player displays are fucked they dont display anything but they still play cds
Posted on Jul 17, 2008
Anonymous
SOURCE: Lost Faceplate for Car Stereo Pioneer Premier DEH-P700BT
e-bay
Posted on Feb 02, 2009
Anonymous
SOURCE: pioneer premier deh-p980bt screen went blank
Its the ribbon cable needs replacing going from the deck to the faceplate
Posted on Aug 13, 2009
How do i detach the faceplate of a pioneer deh-p3700mp car stereo?
Normally it is the button on the top left or bottm right of faceplate. it will spring the faceplate out at an angle, then you just pull off.
Dec 28, 2010 | Pioneer DEH-3700MP CD Player
How to set clock in pioneer deh4000ub
here is the link for your manual:
http://www.pioneer.co.uk/uk/support/manuals/DEH-4000UB/index.html
Setting the clock
This function is available only for DEH-4000UB.
Use these instructions to set the clock.
1 Use MULTI-CONTROL to select
CLOCK SET.
2 Press MULTI-CONTROL to display the
setting mode.
# Press BACK to return to the previous display.
3 Press MULTI-CONTROL to select the segment
of the clock display you wish to set.
Each time you press MULTI-CONTROL, one
segment of the clock display is selected.
Hour—Minute
As you select segments of the clock display,
the selected segment blinks.
4 Turn MULTI-CONTROL to put a clock
right.
# You can also perform the same operations by
pushing MULTI-CONTROL up or down.
Turning the off clock
display on or off
If the off clock display is turned on, the clock
appears on the display when the sources are
off.
OFF CLOCK.
2 Press MULTI-CONTROL to turn the off
clock display on.
# To turn the off clock display
Cheers!
Feb 07, 2010 | Pioneer DEH-P4000UB CD Player
Is there a compatible faceplate to the DEH-3000IB.
no, there is no interchangeable faceplate.
check for a used one on eBay.
THIS faceplate is at $11.50 USD.
Enter deh-p3000ib faceplate in the search.
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
May 07, 2009 | Pioneer DEH-P3000 CD Player
Pioneer DEH-4000UB FM Frequency Range interval
that is strange. try the antenna i think you have an antenna problem. due to the radio locking in on the strongest signal.
Apr 07, 2009 | Pioneer DEH-P4000UB CD Player
I bought a car stereo but it wont save presets.
make sure you have the yellow fuse wire hooked up to bat. power (always hot) red wire is your ignition power
Nov 12, 2008 | Pioneer DEH-1600 CD Player
DEH-P6600 and DEH-P6700
if you still have that deh-p6600 faceplate i'll buy it from you
Sep 25, 2008 | Pioneer DEH-P6600 CD Player
Missing right channel...
The head unit appears to be defective.
Jun 12, 2008 | Pioneer Car Audio & Video
Pioneer DEH-P4000UB CD Player Logo
59 people viewed this question
Top Pioneer Car Audio & Video Experts
Marvin
Marvin
Jeffrey Turcotte
Jeffrey Turcotte
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
