Question about Maytag PYE2300AY Electric Dryer
Maytag electric dryer not heating
I have checked continuity of every part of this dryer- still no heat.  I am far from an electrician, and would like some detailed description on how to check volts on terminal block and pigtail- does it need to be running when I check terminal block?  Wires were a little loose on terminal block connection but does not appear to be burned on either block or pigtail.  Pllease help.
  • 1 more comment
  • Anonymous Nov 02, 2007
    Replaced pigtail-still nothing. Am not getting ANY reading from my voltmeter on new pigtail or block, but dryer is turning. Problem with my voltmeter? Bad breaker on fuse panel? Thanks for your help on this.
    I also gave the wrong model number it is LDE4914ACE
  • dadconsult Aug 23, 2008
    Our dryer stopped heating...still turns but no heat. We replaced the duct hose and cleaned filters, etc. The ground wire is not connected, looks like it never was, (this is my fiance's grandmother's house and dryer was there when she moved in) but would that prevent the dryer from heating?
Michael Masters
  • 6,784 Answers
Check the following to address this issue.
1. No power to the dryer
Make sure there's power getting to the dryer. Check for tripped circuit breakers or blown fuses. An electric dryer uses two circuit breakers or fuses, and if only one of two is tripped or blown, the dryer might still run but not heat. Sometimes the power cord disconnects or burns at the dryer, if this is the case, the wiring and the terminal block must be repaired or replaced.
2. Heating element
A burned out heating element will show no continuity when measured with a meter. Replace the element if found defective.
3. Thermal fuse
Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
Posted on Jun 03, 2009
Mike Johnson
  • 291 Answers
To check the block put meter on 220 volts touch the end of the leads to the outside wires of block.. black and red... should give reading of 220V. IF no reading try one lead at a time with neg side of v meter on ground if you get a reading of 110 one side of the 220 is not coming thu and could be your problem
made sure u checked the hi limit fuse on burner for continuity also
Posted on Nov 01, 2007
  • Mike Johnson
    Mike Johnson Nov 02, 2007
    If you Not getting a reading by checking at the wires hooked at the block on the dryer as posted above... both leads of meter ... one one red wire other lead on black.. should get a reading of 220Volts...
    IF not your only getting one leg or half the 22O... 110 is all your getting .. dryer will run but NO HEAT!
    No reading like posted above = NO Heat
    IF no reading check receptical for 220 there check for loose wires or loose connectors look for anything that looks burnt
Tip
How to Troubleshoot a Clothes Dryer with No Heat
<span>Instructions</span> Things You'll Need: <ul> <li> <span>Volt meter Continuity meter/tester Ohm meter (gas dryers)</span> </li></ul> <ol> For Gas or Electric Dryers <li> 1 Check the setting on the dryer. It's a simple thing, but sometimes people forget that they turned down the dryer for a delicate load.<br /> </li> <li> 2 Check the fuse box. Electric dryers require 240 vaults to run, which means they have a dual breaker switch. If one of the breakers clicks off, the dryer has enough power to run but not enough to produce heat. You may need to replace the fuse to prevent this from happening again.<br /> </li> <li> 3 Check the outlet with a volt meter. As said earlier, electric dryers require 240 vaults to run. If there is not enough power to the outlet, but the fuses are fine, then there is a problem with the wires in your house. You will need to call an electrician.<br /> </li> <li> 4 Check the thermal fuse. Depending on the type of dryer, this fuse will be located either in the front of back of your dryer. It is usually an inch long and mounted in white plastic. Test the fuse using a continuity meter. If the fuse has been blown, replace it.<br /> </li> <li> 5 For electric dryers, locate the heating element on your dryer and test it for continuity using a continuity meter. If it is not working, you will need to replace it.<br /> </li> Gas Dryers Only <li> 1 Check the igniter using an ohm meter. Disconnect the clear plastic connector (called a molex) that attaches the igniter to the burner circuit. Place the probes of the ohm meter on the contacts. It should be below 100 ohms of resistance. If it is above 100 ohms, replace the igniter.<br /> </li> <li> 2 Using an ohm meter, test the continuity between the two contacts on the flame sensor. If there is no continuity, replace the flame sensor.<br /> </li> <li> 3 If none of the above works and you notice that your dryer starts out hot but finishes cold and/or you hear a chattering sound when running the dryer, then your problem is likely with the coils. There is no test for the coils. Your only option is to replace them to determine if this is the cause.<br /> </li></ol>
on Dec 29, 2010 | Dryers
The dryer comes on and starts to heat up then it trips the circuit breaker panel and I have to reset it over and over.what can be causing this
get in an accredited electrician but from your description it appears that there is a problem in the element that is allowing it to short to ground when it gets hot.
Sep 23, 2015 | Dryers
GE dryer dwsr463eg7ww timer isn&#39;t working and doesnt heat up
The heating element assembly warms the air before the air enters the dryer drum. If the dryer won't stop, it may be because the heating element assembly isn't working - which greatly increases the drying time. Check the heating element for continuity. http://www.repairclinic.com/RepairHelp/How-To-Fix-A-Dryer/7-3-850356-/GE-Dryer-won-t-stop-DWSR463EG7WW
This GE Website has descriptions and videos you can watch. Also shows the price of replacement parts and the skill level needed to preform repairs yourself.
Sep 12, 2014 | GE Dryers
Electric dryer model # 110.68422700 type:dwjr-ele-2406028-fm54. Heater not working. I am an electrician so when i get my meter I will check points. Just sort of wondering what to check and where? Also just...
take the back off the heating element will be on the right side as you face the back of the dryer inside a metal container. The heating element is resistor wire. The other part that commonly goes bad is a thermal fuse it will be connected to the heating element but mounted on the back of the dryer near the bottom center right. The fuse should show continuity so should the heating element. Elements sometimes ck good but if you shake them the wire will seperate.
Aug 10, 2010 | Kenmore Dryers
Im at a complete loss with my dryer. It runs but doesnt heat
Check the 230v very carefully You may be hooking it up even with new wire just like the old. You have to have across the line 230
not just 230. Sounds like you need to have an electrician to check
230 across the line at the wall.
Let me know.
Leo Ponder
[email protected]
Jul 22, 2010 | Whirlpool GEW9250 Electric Dryer
Dryer runs but dosn't heat any ideas would be appreciated
Visually verify household fuse blown or a circuit breaker tripped.
The drum may be turning, but you may not have heat. Electric dryers use 2 household fuses or circuit breakers. Replace the fuse or reset the circuit breaker.
If the problem continues, call an electrician.
Good Luck and have a nice day.
Rating the solution is highly appreciated.
Jun 16, 2010 | Miele Novotronic T220 Electric Dryer
Won't heat
Jun 16, 2010 | Whirlpool LER5636P Electric Dryer
Dryer heat not working
Jun 16, 2010 | Whirlpool GEW9200L Electric Dryer
My dryer is not producing any heat all air coming out of vent is cool
The easiest thing to check is the heating element. You will need to unplug the dryer from the wall remove the back cover or if access can be granted to the bottom go there. Find where the heating element(s) connect to the main set of wires and do a continuity test with a multimeter. If it tests bad (no continuity) then you should remove the element and order a replacement.
Aug 11, 2009 | Kenmore 800 7982 Dryer
Maytag PYE2300AY Electric Dryer Logo
502 people viewed this question
Top Maytag Dryers Experts
Marvin
Marvin
Gerry Harvey
Gerry Harvey
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
