Question about Hotpoint Refrigerators
Fridge is A1 but the freezer is off completely
One of two things could be a problem . 1 short of refrigerant 2 the evaporator in the freezer could have a thick covering of Ice or frost both of which will act as an insulator causing the refrigerant to flow through as a liquid rather than expanding to a vapour if this is the case this is a reaction to something else which will be the fault eg covered in ice could be the drain is blocked the water doesnt run away so it freezes could be door seal, could be faulty fan in freezer
Posted on May 30, 2014
Hi Alan Hobson, I want to help you with your problem, but I need more information from you. Do you have the full model number?
SEVERAL STICKERS ON REAR , NONE OF THEM WITH A MODEL NUMBER I M AFRAID
