Check the speaker/s first. If found OK; check and replace the damaged component/s at its audio output section circuit board. If needy, replace this board as card basis. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy. Surf the site with patience. Pull up older posts. Surf the site with patience.
SOURCE: Syntax Oleiva 50 in. LCD tv?
Lcd tv's do not have color wheels in them, only DLP sets have them along with projectors. DLP sets are the ones with the single lamp, color wheel, light tunnel,,ect...Send me your Model number and the problem your having, I'll do the rest....
SOURCE: I have sound but no picture on an Olevia 237V
If you get no picture on all inputs (TV, DVD, ETC.) then the problem can be in the backlight inverter board or the power supply that supplys the power to the inverter board.
SOURCE: need remote codes to connect with my Time Warner
Would have to know what digital box you have. On the back you should have a model number, and there maybe a separate brand other than time warner.
